Arduino with 8MHz crystal
I built a barebones board which I want to program using an FTDI cable in the Arduino environment. When I try to upload programs the IDE fives a sync error message. Is that due to the 8MHz crystal ? Do I need to change some settings somewhere to take account of the different crystal ?
I had a look on playground and there was an article which said change preference.txt, but I couldn't find the crystal freq in that file.
Thanks
What board do you have selected under Tools->Boards? You should select an 8 MHz board. If none of the existing 8 MHz boards matches your breadboard you should write your own boards.txt file to add your breadboard. Maybe something like this but with setting for a crystal:
atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
atmega328bb.upload.protocol=stk500
atmega328bb.upload.maximum_size=30720
atmega328bb.upload.speed=57600
atmega328bb.bootloader.low_fuses=0xE2
atmega328bb.bootloader.high_fuses=0xD9
atmega328bb.bootloader.extended_fuses=0x07
atmega328bb.bootloader.path=arduino:atmega
atmega328bb.bootloader.file=ATmegaBOOT_168_pro_8MHz.hex
atmega328bb.bootloader.unlock_bits=0x3F
atmega328bb.bootloader.lock_bits=0x0F
atmega328bb.build.mcu=atmega328p
atmega328bb.build.f_cpu=8000000L
atmega328bb.build.core=arduino:arduino
I'm using atmega328PU with a 8MHz crystal. IDE Arduino 0022 and none of the boards on list match. I'll try a custom board definition as you suggest.
Many Thanks
Hi, I had a stab at doing a custom board in boards.txt.
Although My board has an external crystal I decided to try (for now) 8MHz internal clock. I used ADABoot (I think it uses internal clock 8MHz - but this could be wrong)
I have set the fuses for 8MHz internal clock using AVRstudio 4. I then tried this board in boards .txt
I put the ADABoot_328 HEX file in the file path: /atmega328.bootloader.path=atmega. I used a low baud rate for safety (9600). Set Baud for cable at 9600 also.
atmega328x.name=Arduino Xino w/ATmega328-PU 8MHz internal clock
atmega328x.upload.protocol=stk500
atmega328x.upload.maximum_size=30720
atmega328x.upload.speed=9600
atmega328x.bootloader.low_fuses=0xFF
atmega328x.bootloader.high_fuses=0xDA
atmega328x.bootloader.extended_fuses=0x05
atmega328x.bootloader.path=atmega
atmega328x.bootloader.file=ADABoot_328
atmega328x.bootloader.unlock_bits=0x3F
atmega328x.bootloader.lock_bits=0x0F
atmega328x.build.mcu=atmega328p
atmega328x.build.f_cpu=8000000L
atmega328x.build.core=arduino
It still doesn't work with cable. Still getting sync error in IDE.
"avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51"
Am I on the right track?
Thanks
johnwasser:
copy this in your boards.txt file and you'll have the new board in the board menĂ¹
hi nk
Did you burn the bootloader?
I've been using the attached 8MHz version of Optiboot. I modified the boards.txt entry for the 8MHz Pro Mini as follows. Also see similar thread here.
pro328.name=Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328
pro328.upload.protocol=stk500
pro328.upload.maximum_size=32256
pro328.upload.speed=57600
pro328.bootloader.low_fuses=0xFF
pro328.bootloader.high_fuses=0xDE
pro328.bootloader.extended_fuses=0x05
pro328.bootloader.path=optiboot
pro328.bootloader.file=optiboot_atmega328_pro_8MHz.hex
#pro328.bootloader.path=atmega
#pro328.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex
pro328.bootloader.unlock_bits=0x3F
pro328.bootloader.lock_bits=0x0F
pro328.build.mcu=atmega328p
pro328.build.f_cpu=8000000L
pro328.build.core=arduino
optiboot_atmega328_pro_8MHz.hex (1.43 KB)
Many thanks to all for the input. The following board settings worked with the bootloader suggested by Jack.
http://proto-pic.co.uk/xino-basic-for-the-atmel-atmega-series-and-arduino/
xino328.name=Arduino xino (3.3V, 8 MHz) w/ ATmega328
xino328.upload.protocol=stk500
xino328.upload.maximum_size=32256
xino328.upload.speed=57600
xino328.bootloader.low_fuses=0xFF
xino28.bootloader.high_fuses=0xDE
xino328.bootloader.extended_fuses=0x05
xino328.bootloader.path=optiboot
xino328.bootloader.path=atmega
xino328.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex
xino328.bootloader.unlock_bits=0x3F
xino328.bootloader.lock_bits=0x0F
xino328.build.mcu=atmega328p
xino328.build.f_cpu=8000000L
xino328.build.core=arduino
cheers
