I have a pressure transducer that outputs 0-5V. I also have an AD7705 I want to use the get the really high sample rate. The AD7705 sheet says it can handle unipolar analog input from 0-2.5V, so I'm guessing I need to make a voltage divider upstream of the AD7705. I also guess I don't need any gain. Do I just go from divider into AIN1+ and AIN1-? Do I need to use a reference voltage? Do I need to do anything special to get the max sampling rate?
There is no point in sampling faster than 1000 Hz, which is trivial for the built in ADC of any Arduino. I did not see the response time mentioned in either of the linked documents, though.
Can you show that math? The G2 performance is stated +/- 0.25%. You have 1023 counts for the Uno, 0-5V, where the +5V is the unstable USB voltage as reference. 5/1023.
