Arduino with Atmega8 / No Bootloader / No Xtal
Hello guys,
I have a little question, i will use for some projects some Atmega8 chips, and i would like to use Arduino IDE to program them.
Q1. I've made the following modifications in my boards file (i've used Arduino NG section):
atmegang.name=Arduino NG or older
atmegang.upload.tool=avrdude
atmegang.upload.protocol=arduino
atmegang.upload.speed=19200
atmegang.bootloader.tool=avrdude
atmegang.bootloader.unlock_bits=0x3F
atmegang.bootloader.lock_bits=0x0F
atmegang.build.mcu=atmegang
atmegang.build.f_cpu=8000000L
atmegang.build.board=AVR_NG
atmegang.build.core=arduino
atmegang.build.variant=standard
## Arduino NG or older w/ ATmega168
atmegang.menu.cpu.atmega168=ATmega168
atmegang.menu.cpu.atmega168.upload.maximum_size=14336
atmegang.menu.cpu.atmega168.upload.maximum_data_size=1024
atmegang.menu.cpu.atmega168.bootloader.low_fuses=0xff
atmegang.menu.cpu.atmega168.bootloader.high_fuses=0xdd
atmegang.menu.cpu.atmega168.bootloader.extended_fuses=0x00
atmegang.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_ng.hex
atmegang.menu.cpu.atmega168.build.mcu=atmega168
## Arduino NG or older w/ ATmega8
atmegang.menu.cpu.atmega8=ATmega8
atmegang.menu.cpu.atmega8.upload.maximum_size=8191
atmegang.menu.cpu.atmega8.upload.maximum_data_size=1024
atmegang.menu.cpu.atmega8.bootloader.low_fuses=0xdf
atmegang.menu.cpu.atmega8.bootloader.high_fuses=0xca
atmegang.menu.cpu.atmega8.bootloader.file=atmega8/ATmegaBOOT-prod-firmware-2009-11-07.hex
atmegang.menu.cpu.atmega8.build.mcu=atmega8
The size of maximum upload seems correct? 8191 is it ok (1024 x 8 = 8192)
I will burn the FUSES with USBASP programmer so ... i guess there will be no need to use fuse configuration keys, am i right?
Thank you in advance and best regards,
Gabriel Tudoran
I guess. I'm not sure why you couldn't set it all the way up to 8192.
Your fuse values are pretty far off from what they should be. (I get E4 DB)
As you say, it won't matter, if you're setting them from elsewhere, but you do need to come up with the correct values.
(Right now, you don't have the internal oscillator selected, and you still have the BOOTRST fuse set, even though you're not using a bootloader.)
Thank you for your fast reply. Yes i know my fuses should be: E4 D1 . I use only IDE, so the rest will be put from elsewhere. I guess the fuse settings will be ok with E4 D1?
Best regards,
Gabriel Tudoran
PS: i've put 8191, because i think memory starts with index 0... that would give me 8192 locations.
Were you able to program ATMEGA8 without bootloader, using Arduino as ISP? If yes, please do share your method.
Thanks.
