Arduino with Blynk no quite working
Hi all.
I am using an app called Blynk to run my Mega. I have three temp sensors attached on D44. These are returned to the serial monitor every second. However as soon as I start to integrate the Blink coding, it stops giving me my serial print data.
This is before the Blynk bits...
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
float tempC01, tempC02, tempC03;
//////////// Temperature sensor start ////////////
// Data wire is plugged into port 12 on the Arduino
#define ONE_WIRE_BUS_PIN 44
OneWire oneWire(ONE_WIRE_BUS_PIN);
DallasTemperature sensors(&oneWire);
DeviceAddress Probe01 = { 0x28, 0x5E, 0x72, 0xC5, 0x06, 0x00, 0x00, 0xA4 };
DeviceAddress Probe02 = { 0x28, 0x9F, 0x49, 0x2F, 0x06, 0x00, 0x00, 0xAA };
DeviceAddress Probe03 = { 0x28, 0x7A, 0xFB, 0xC4, 0x06, 0x00, 0x00, 0x79 };
//////////// Temperature sensor end ////////////
  // Initialize the Temperature measurement library
  sensors.begin();
  // set the resolution to 10 bit (Can be 9 to 12 bits .. lower is faster)
  sensors.setResolution(Probe01, 10);
  sensors.setResolution(Probe02, 10);
  sensors.setResolution(Probe03, 10);
  sensors.requestTemperatures();
  tempC01 = sensors.getTempC(Probe01);      // Tank
  tempC02 = sensors.getTempC(Probe02);      // Sump
  tempC03 = sensors.getTempC(Probe03);      // LEDS
  Serial.print("Probe 1 (Tank) = ");
  Serial.println(DallasTemperature::toFahrenheit(tempC01));
  Serial.print("Probe 2 (Sump) = ");
  Serial.println(DallasTemperature::toFahrenheit(tempC02));
  Serial.print("Probe 3 (LEDS) = ");
  Serial.println(DallasTemperature::toFahrenheit(tempC03));
  Serial.println("----------------------");
This is with the Blynk code mingled in...
#define BLYNK_PRINT Serial1
#include <Wire.h>
#include <BlynkSimpleStream.h>
char auth[] = "65b59e****************************5f4166";
#define PIN_UPTIME V5
BLYNK_READ(PIN_UPTIME)
  // This command writes Arduino's uptime in seconds to Virtual Pin (5)
  Blynk.virtualWrite(PIN_UPTIME, millis() / 1000);
  Serial1.begin(9600);
  sensors.begin();
  Blynk.begin(Serial1, auth);
  Blynk.run();
This is the line that is causing the problems that I found through trial and error...
Any ideas why and how I can resolve this?
Thanks, Steve.
What is ACTUALLY connected to the RX1 and TX1 pins?
Nothing is physically connected to them.
stevelondon2:
Then, how do you expect Blynk to get data?
