I planned to use acs712 current sensor for ac current measurement . I got the Arduino code and is working pretty well in proteus and it has lcd displaying of the current value . below is the code for the above mentioned work .
what i expect is the value of current that arduino serial prints can be displayed in BLYNK app by means of ESP8266 wifi shield in a Superchart widget . And i really dont know if theres a possibilty that this arduino code could be pasted in between some default program codes to carry out what i expect .
plz dont bother about the logic of the problem . Look at the end , you will see that arduino is trying to serial print required data . And i'm only using a void setup and void loop . what all things will add up .
Plz help !
// include the library code:
#include <LiquidCrystal.h> //library for LCD
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8, 9, 10, 11, 12, 13);
//Measuring Current Using ACS712
int pinOut = 7;
const int analogchannel = 0; //Connect current sensor with A0 of Arduino
int sensitivity = 66; // use 100 for 20A Module and 66 for 30A Module
float adcvalue= 0;
int offsetvoltage = 2500;
double Voltage = 0; //voltage measuring
double ecurrent = 0;// Current measuring
//baud rate
Serial.begin(9600);//baud rate at which arduino communicates with Laptop/PC
// set up the LCD's number of columns and rows:
pinMode(7, OUTPUT);
lcd.begin(20, 4); //LCD order
// Print a message to the LCD.
lcd.setCursor(1,1);//Setting cursor on LCD
lcd.print("MICROCONTROLLERSLAB");//Prints on the LCD
lcd.setCursor(4,2);
lcd.print(".com");
delay(3000);//time delay for 3 sec
lcd.clear();//clearing the LCD display
lcd.display();//Turning on the display again
lcd.setCursor(1,0);//setting LCD cursor
lcd.print("Reading Values from");//prints on LCD
lcd.setCursor(1,1);
lcd.print("DC Current Sensor");
lcd.setCursor(5,2);
lcd.print("ACS 712");
delay(10000);//delay for 2 sec
void loop() //method to run the source code repeatedly
unsigned int temp=0;
float maxpoint = 0;
int i=0;
for(i=0;i<500;i++)
if(temp = analogRead(analogchannel),temp>maxpoint)
maxpoint = temp;
adcvalue = maxpoint;
Voltage = (adcvalue / 1024.0) * 5000; // Gets you mV
ecurrent = ((Voltage - offsetvoltage) / sensitivity);
ecurrent = ( ecurrent ) / ( sqrt(2) );
lcd.clear();//clears the display of LCD
delay(1000);//delay of 1 sec
lcd.display();
lcd.setCursor(1,0);
Serial.print("\t ecurrent = "); // shows the voltage measured
Serial.println(ecurrent,3);// the '3' after voltage allows you to display 3 digits after decimal point
lcd.setCursor(1,2);
lcd.print("ac Current = ");
lcd.setCursor(11,2);
lcd.print(ecurrent,3);
lcd.setCursor(16,2);
lcd.print("A"); //unit for the current to be measured
delay(2500); //delay of 2.5 sec
