I connected 2 12v drill motors to my arduino uno with motor shield. I hooked up an external power supply of 12 volts but the motors won't move. I tested the code and controller with smaller motors after I tried the big motors and it worked perfectly. I don't know what's wrong.
Maybe the huge current the motors draw burned out your motor shield.
Most likely the motor controller can't pass enough current to operate the larger motors. You probably need a controller that can handle more current.
Drill motors are way way beyond the ability of a lowly L298 or L293 motor shield, they are
seriously high current motors (30A or something of that order).
Try with a high current shield, like bts7960 or higher ones, they sell on ebay capacity like 50-100 amps
Drill motors are not designed to run continuously, note, they may overheat if expected
to do continuous duty.
What are you trying to do?
