these are the error messages i have got
Arduino: 1.8.8 (Windows 7), Board: "Arduino/Genuino Uno"
Ultrasonic_Sensor_HC-SR04_with_NewPing:22:4: error: stray '\342' in program
Serial.println(“cm�);
Ultrasonic_Sensor_HC-SR04_with_NewPing:22:4: error: stray '\200' in program
Ultrasonic_Sensor_HC-SR04_with_NewPing:22:4: error: stray '\234' in program
Ultrasonic_Sensor_HC-SR04_with_NewPing:22:4: error: stray '\235' in program
C:\Users\home\AppData\Local\Temp\Temp1_Ultrasonic_Sensor_HC-SR04_with_NewPing.zip\Ultrasonic_Sensor_HC-SR04_with_NewPing\Ultrasonic_Sensor_HC-SR04_with_NewPing.ino: In function 'void loop()':
Ultrasonic_Sensor_HC-SR04_with_NewPing:22:22: error: 'cm' was not declared in this scope
exit status 1
option enabled in File -> Preferences.
this is the code that i want to upload. i have installed the new ping library for IDE library manager plz check about it
* Posted on http://randomnerdtutorials.com
* created by http://playground.arduino.cc/Code/NewPing
#include <NewPing.h>
#define TRIGGER_PIN 12
#define ECHO_PIN 11
#define MAX_DISTANCE 200
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
delay(50);
unsigned int uS = sonar.ping_cm();
Serial.print(uS);
Serial.println(“cm”);
