Arduino with Humidity sensor and 28BYJ-48 stepper motor
Hi there,
I am trying to read an analog input from a humidity sensor. I need a delay of 2 seconds to properly read the humidity and the temperature. The stepper motor needs just 2 ms to be able to rotate. With a 2 second delay in the same loop the rotation is barely visible. Is there any way to isolate the 2 codes to make the stepper run properly with the sensor?
Here is the code I used:
#include <dht.h>
#define DHT11_PIN A0
#define STEPPER_PIN_1 8
#define STEPPER_PIN_2 9
#define STEPPER_PIN_3 10
#define STEPPER_PIN_4 11
dht DHT;
int step_number = 0;
pinMode(STEPPER_PIN_1, OUTPUT);
pinMode(STEPPER_PIN_2, OUTPUT);
pinMode(STEPPER_PIN_3, OUTPUT);
pinMode(STEPPER_PIN_4, OUTPUT);
int chk = DHT.read11(DHT11_PIN); // the follow is just so that I can     see the readings come out properly
    Serial.print("Temperature = ");
    Serial.println(DHT.temperature);
    Serial.print("Humidity = ");
    Serial.println(DHT.humidity);
if (DHT.humidity > 60)
    OneStep (true); //Function makes the stepper run clockwise
    delay(2);
else if (DHT.humidity < 60)
    OneStep (false); //Function makes the stepper run counter clockwise
     delay(2);
void OneStep(bool dir){
    if(dir){
switch(step_number){
  case 0:
  digitalWrite(STEPPER_PIN_1, HIGH);
  digitalWrite(STEPPER_PIN_2, LOW);
  digitalWrite(STEPPER_PIN_3, LOW);
  digitalWrite(STEPPER_PIN_4, LOW);
  case 1:
  digitalWrite(STEPPER_PIN_1, LOW);
  digitalWrite(STEPPER_PIN_2, HIGH);
  case 2:
  digitalWrite(STEPPER_PIN_3, HIGH);
  case 3:
  digitalWrite(STEPPER_PIN_4, HIGH);
  }else{
  case 0:
  case 1:
  case 2:
  case 3:
step_number++;
  if(step_number > 3){
    step_number = 0;
Use a non-blocking DHT library. You can “properly” read H and T by allowing a 2 second interval. That doesn’t mean you have to sit and wait 2 seconds. You can be doing other things like stepping a stepper, and that is what a non-blocking library does.
Thanks for the qucik reply. How can I implement these non-blocking functions? I am already using a DHT library and I cannot find a way to do it.
