I have to display the temperature and the humidity with Arduino, Processing and to do a simulation with Isis Proteus. I'm not going to talk about Processing.
My Arduino code :
int temperature;
temperature = analogRead(A1);
Serial.println(temperature);
My temperature is done, now I want to code the humidity. Can you help me to add a code for the humidity and the simulation ?
Otosaka:
'k, I'm using the DHT11 temperature-humidity sensor.
So, why are you using analogRead()? That is NOT how to read that sensor. There are a variety of libraries that can read both temperature and humidity from that. Use one, and simply call the correct method.
PaulS:
I'm using analogRead() for the simulation as you can see in the screenshot of my simulation, the temperature is in the analogRead(A1)
Now, I'm not going to do a simulation but with a real sensor, that's why my code is false. I'm trying to do something, I will update this post, thanks for you help !
