Arduino with Maxbotix LV-EZ1 ultrasonic sensors
I read this tutorial http://arduino.cc/en/Tutorial/Ping?from=Tutorial.UltrasoundSensor and the writer said that it can be used on Max LV-EZ1. I just wanted to know which pin on the EZ1 is equivilant to the SIG pin on the PING sensor ?
here is the datasheet for the EZ1:
RobotShop | Robot Store | Robots | Robot Parts | Robot Kits | Robot Toys
The easiest to read from an arduino is from the pin labeled "AN" (analog) which will give a voltage proportional to the distance detected. Just analogRead it and calculate the distance based on the info on the datasheet.
#define apin 0
void setup(){
  Serial.begin(38400);
void loop(){
  Serial.println(analogRead(apin));
Yes I did that but the values wasn't so accurate.It was more accurate when I used to use the Axon.
hi,
the code works , but I get some noise,
like low values mixed with high values
I was able to smooth out some of the noise using an averaging loop. See here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1226321702/5#5
