Arduino with Modbus RTU
Is it possible to connect Arduino Nano, Mega or Uno to a device using Modbus RTU protocol?
I have read an articles stated that modbus library is not compatible with above arduinos.
Are there any workarounds?
Currently I am able to to connect 3 distance sensors to arduino Mega using TTL serial. But it takes 3 serial ports for the sensors which leave no rooms for further expansions such as serial display, serial printer, etc.
Fortunately the sensor also support Modbus RTU, which I support multi-points.
Pls advise.
Regards,
Bronson
The Library ModbusMaster by Doc Walker is working fine on Nano, Mega, Uno.
From these 3 microcontrollers I would chose the Mega due to its additional HW serials
Thank you for replying.
I will test the library as you suggest.
Thx
