Arduino with MQTT
Hi, I know this is an arduino Forum. But i really did not find any help on mqtt forums. So just thought i would give it a try here.
I am working with the arduino PubSubClient library. Simple code. But it seems to not functions.
The client is not publishing messages to the broker. I cannot understand why. There is definitely a problem with the code. Because the client is able to publish when i put it at the end of the void loop().
Here is my code. Any kind of help is appreciated. Thank you.
  if (!mqttClient.connected()) {
    reconnect();
mqttClient.loop();
  int xyz = 2;
  if (abc == 1){
    Serial.println("Starting Sensor");
     digitalWrite(5, HIGH);
    Serial.print("calibrating sensor ");
    for(int i = 0; i < calibrationTime; i++){
      Serial.print(".");
    Serial.println(" done");
    Serial.println("SENSOR ACTIVE");
    delay(50);
    digitalWrite(12, HIGH);
  Serial.println("wait till module gains stability");
  delay(5000);
  //for (int x=0; x<20; x++){
    while (xyz != 1){
    Serial.println("Started Detection");
  if(digitalRead(pirPin) == HIGH){
       //digitalWrite(ledPin, HIGH);
Serial.println("motion detected ");
    xyz = 1;
  digitalWrite(14, HIGH);
delay (1000);
  abc = 2;
  if(xyz > 0){
  mqttClient.publish("Daccess/MotionSensor/status","Motion Detected");
