alright I get this
what else does it need?
@JaGa, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project
See About the Installation & Troubleshooting category.
ok, sorry for that!
//is pump1 now OFF ?
if (pump1State == PUMPoff)
digitalWrite(pump1Relay, PUMPon);
pump1State = PUMPon;
pump1_interval = pump1_ON_time;
When the pump is OFF, the above code will execute resulting the the pump turning ON.
pump1_interval = pump1_ON_time; makes our target time 2 seconds.
When the pump1 is ON the code below is executed:
digitalWrite(pump1Relay, PUMPoff);
pump1State = PUMPoff;
pump1_interval = pump1_OFF_time;
pump1_interval = pump1_OFF_time; this makes our target 5 seconds
ok, now ill try if I can apply this to the other pump
Good
#define CLOSED LOW
#define OPENED HIGH
#define ENABLED true
#define DISABLED false
#define PUMPon LOW
#define PUMPoff HIGH
boolean switchFlag = !ENABLED;
const byte pump1Relay = 2;
const byte pump2Relay = 4;
const byte SWITCH1 = 7;
const byte heartbeatLED = 13;
byte lastSwitch1State = OPENED;
byte pump1State = PUMPoff;
byte pump2State = PUMPoff;
unsigned long pump1Millis;
unsigned long pump2Millis;
unsigned long heartbeatMillis;
unsigned long switchMillis;
unsigned long time_1;
unsigned long time_2;
unsigned long pump1_interval;
unsigned long pump2_interval;
// PUMP 1
const unsigned long pump1_OFF_time = 5000;
const unsigned long pump1_ON_time = 2000;
// PUMP 2
const unsigned long pump2_OFF_time = 180000; //Pump 2 Change for delay (1000 = 1 second)
const unsigned long pump2_ON_time = 5000; //Pump 2 Change for pump running time (1000 = 1 second)
pinMode(heartbeatLED, OUTPUT);
pinMode(pump1Relay, OUTPUT);
pinMode(pump2Relay, OUTPUT);
pinMode(SWITCH1, INPUT_PULLUP);
digitalWrite(pump2Relay, PUMPoff);
} //END of setup()
//************************************* h e a r t b e a t T I M E R
//to see if the sketch is blocking,
//toggle the heartbeat LED every 500ms
if (millis() - heartbeatMillis >= 500)
//restart the TIMER
heartbeatMillis = millis();
//toggle the LED
digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
//************************************* c h e c k S w i t c h T I M E R
//is it time to read the switches ?
if (millis() - switchMillis >= 50)
//restart the TIMER
switchMillis = millis();
checkSwitches();
//if the switch is 'not enabled' we can proceed with autmatic operation
if (switchFlag == !ENABLED)
//is it time to toggle the pump relay ?
if (millis() - pump1Millis >= pump1_interval)
//restart the TIMER
pump1Millis = millis();
if (millis() - pump2Millis >= pump2_interval)
pump2Millis = millis();
if (pump2State == PUMPoff)
digitalWrite(pump2Relay, PUMPon);
pump2State = PUMPon;
pump2_interval = pump2_ON_time;
pump2_interval = pump2_OFF_time;
} //END of loop()
void checkSwitches()
//********************************************* S W I T C H 1
//userSwitch code
byte currentState = digitalRead(SWITCH1);
//was there a change in state ?
if (lastSwitch1State != currentState)
//update to the new state
lastSwitch1State = currentState;
//********************** C L O S E D
//is the switch closed ?
if (currentState == CLOSED)
//allow manual switch bypass
switchFlag = ENABLED;
//********************** O P E N E D
if (currentState == OPENED)
//toggle switch1
//cancel manual switch bypass
switchFlag = DISABLED;
} //END of userSwitch code
//********************************************* o t h e r S w i t c h e s
//next switch code
} //END of checkSwitches()
now I'm struggling again with the second switch, but Ill try again ![]()
can't find the mistake?!
#define CLOSED LOW
#define OPENED HIGH
#define PUMPon LOW
const byte SWITCH2 = 8;
byte lastSwitch2State = OPENED;
// PUMP 1
// PUMP 2
} //END of setup()
//restart the TIMER
//toggle the LED
//restart the TIMER
checkSwitches();
//restart the TIMER
} //END of loop()
//userSwitch code
//toggle switch1
//next switch code
//********************************************* S W I T C H 2
//userSwitch code
byte currentState = digitalRead(SWITCH2);
if (lastSwitch2State != currentState)
lastSwitch2State = currentState;
//toggle switch2
it doesn't show me a mistake, but something is still not right. The switch2 doesn't work
#define CLOSED LOW
#define OPENED HIGH
#define PUMPon LOW
// PUMP 1
// PUMP 2
} //END of setup()
//restart the TIMER
//toggle the LED
//restart the TIMER
checkSwitches();
//restart the TIMER
} //END of loop()
//userSwitch code
//userSwitch code
//toggle switch1
//toggle switch2
} //next switch code
You will need two flags, one for each switch:
boolean switch1Flag = !ENABLED;
boolean switch2Flag = !ENABLED;
I don't know why but pump relay one acs now very strange, it goes on and off directly
#define CLOSED LOW
#define OPENED HIGH
#define PUMPon LOW
// PUMP 1
// PUMP 2
const unsigned long pump2_OFF_time = 5000; //Pump 2 Change for delay (1000 = 1 second)
const unsigned long pump2_ON_time = 2000; //Pump 2 Change for pump running time (1000 = 1 second)
pinMode(SWITCH2, INPUT_PULLUP);
} //END of setup()
//restart the TIMER
//toggle the LED
//restart the TIMER
checkSwitches();
if (switch1Flag == !ENABLED)
//restart the TIMER
} //END of loop()
//userSwitch code
//userSwitch code
switch1Flag = ENABLED;
//toggle switch1
switch1Flag = DISABLED;
switch2Flag = ENABLED;
//toggle switch2
switch2Flag = DISABLED;
Should be:
if (switch2Flag == !ENABLED)
//*********************************** p u m p 2 T I M E R
//restart the TIMER
like this?
#define CLOSED LOW
#define OPENED HIGH
#define PUMPon LOW
// PUMP 1
// PUMP 2
} //END of setup()
//restart the TIMER
//toggle the LED
//restart the TIMER
checkSwitches();
//restart the TIMER
//restart the TIMER
} //END of loop()
//userSwitch code
//userSwitch code
//toggle switch1
//toggle switch2
You cannot just copy and paste things in a helter skelter fashion.
You are not handling the switches properly.
Always format your code by pressing CTRL T
ok, I'll try again. thanks!!
//restart the TIMER
// W H E R E I S T H E R E S T O F T H E C O D E
omg I lost track, its confusing
#define CLOSED LOW
#define OPENED HIGH
#define PUMPon LOW
// PUMP 1
// PUMP 2
} //END of setup()
//restart the TIMER
//toggle the LED
//restart the TIMER
checkSwitches();
//restart the TIMER
//restart the TIMER
//*********************************** p u m p 1 T I M E R
//restart the TIMER
//END of loop()
//userSwitch code
//userSwitch code
//toggle switch1
//toggle switch2
