Hello,
I am using an Arduino UNO with a RFID scanner that triggers a relay with a lock behind it.
It sends an HTTP GET request to my website and gets either true or false back.
If the response is true, the lock opens.
This is all working except that it gets stuck sometimes.
Resetting the board works but it gets stuck a bit later again.
This is the code I'm using
#include <ArduinoJson.h>
#include <Ethernet.h>
#include <SPI.h>
#include <EEPROM.h>
#include <MFRC522.h>
#include <Servo.h>
#define COMMON_ANODE
#ifdef COMMON_ANODE
#define LED_ON LOW
#define LED_OFF HIGH
#else
#define LED_ON HIGH
#define LED_OFF LOW
#endif
#define redLed 7 // Set Led Pins
#define greenLed 6
#define blueLed 5
#define relay 2 // Set Relay Pin
/////// RFID Settings ///////
#define RST_PIN 3
#define SS_PIN 4
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
int statusCode = 0;
/////// Keypad Settings ///////
/////// Servo Settings ///////
Servo lock; //declares servo
String getReq, tag, rfid, pincode;
int rStatus = 0; // RFID Status
int pStatus = 0; // PIN Status
String registeredCard = "160196116163";
pinMode(redLed, OUTPUT);
pinMode(greenLed, OUTPUT);
pinMode(blueLed, OUTPUT);
pinMode(relay, OUTPUT);
//Be careful how relay circuit behave on while resetting or power-cycling your Arduino
digitalWrite(redLed, LED_OFF); // Make sure led is off
digitalWrite(greenLed, LED_OFF); // Make sure led is off
digitalWrite(blueLed, LED_OFF); // Make sure led is off
// Initialize Serial port
while (!Serial) continue;
// Initialize Ethernet library
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0x0F};
if (!Ethernet.begin(mac)) {
Serial.println(F("Failed to configure Ethernet"));
/////// RFID Setup ///////
Serial.println("Initializing RFID Module.");
mfrc522.PCD_Init(); // Initiate MFRC522
Serial.println("RFID Ready.");
Serial.println("");
/////// Keypad Setup ///////
Serial.println("Setting up servo motor...");
lock.attach(13);
Serial.println("Servo Motor Ready.");
Serial.println("");
Serial.println("Please tap RFID Card.");
digitalWrite(relay, LOW); // Make sure door is locked
if (rStatus == 0)
readRFID();
if (rStatus == 1)
rStatus = 0;
Serial.println("Opening lock");
digitalWrite(relay, HIGH); // Make sure door is unlocked
delay(5000);
Serial.println("Closing lock");
Serial.println("test");
rStatus = 0;
void request(String rfid) {
Serial.println(F("Connecting..."));
// Connect to HTTP server
EthernetClient client;
client.setTimeout(10000);
if (!client.connect("mylink.com", 80)) {
Serial.println(F("Connection failed"));
return;
Serial.println(F("Connected!"));
// Send HTTP request
client.println("GET /gates/check?sid=RFID0002&pid=" + rfid + " HTTP/1.0");
client.println(F("Host: mylink.com"));
client.println(F("Connection: close"));
if (client.println() == 0) {
Serial.println(F("Failed to send request"));
return;
// Check HTTP status
char status[32] = {0};
client.readBytesUntil('\r', status, sizeof(status));
if (strcmp(status, "HTTP/1.1 200 OK") != 0) {
Serial.print(F("Unexpected response: "));
Serial.println(status);
return;
// Skip HTTP headers
char endOfHeaders[] = "\r\n\r\n";
if (!client.find(endOfHeaders)) {
Serial.println(F("Invalid response"));
return;
// Allocate the JSON document
// Use arduinojson.org/v6/assistant to compute the capacity.
const size_t capacity = JSON_OBJECT_SIZE(3) + JSON_ARRAY_SIZE(2) + 60;
DynamicJsonDocument doc(capacity);
// Parse JSON object
DeserializationError error = deserializeJson(doc, client);
if (error) {
Serial.print(F("deserializeJson() failed: "));
Serial.println(error.c_str());
return;
// Extract values
Serial.println(F("Response:"));
String response = doc["access"].as<String>();
Serial.println(response);
if (response == "true") {
Serial.println("Open Gate");
rStatus = 1;
Serial.println("No access");
rStatus = 0;
// Disconnect
client.stop();
void readRFID()
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
//Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("PID tag : ");
String content = "";
//byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
//Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
//Serial.print(mfrc522.uid.uidByte[i], HEX);
//content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
//Serial.print(mfrc522.uid.uidByte[i]);
//content.concat(String(mfrc522.uid.uidByte[i]));
}http://192.168.0.74/mjpg/video.mjpg?timestamp=1587029376092
Serial.println(content);
tag = String(content);
request(tag);
//Serial.println(rfid);
Serial.println("End of scan loop");
I tried diffrent boards / ethernet shields aswell but it doesn't solve the problem.
