Arduino with SD Card Memory Leak
I would like listing files on Arduino with SD card.
#include <MemoryFree.h>
#include <SD.h>
String current_directory;
File directory;
File filesystem_member;
void list_files(void)
  Serial.print("Directory: ");
  Serial.print(current_directory);
  while (filesystem_member = directory.openNextFile())
    Serial.write('\n');
    Serial.print(filesystem_member.name());
    if (!filesystem_member.isDirectory())
      Serial.write('\t');
      Serial.print(filesystem_member.size());
      Serial.print(F(" byte"));
      Serial.write('\n');
    filesystem_member.close();
  directory.rewindDirectory();
  SD.begin();
  list_files();
  Serial.println(freeMemory());
  directory = SD.open("/");
void_loop()
  list_files();
  delay(2000);
But, the code has memory leak problem. Free memory are decreasing.
Has Arduino a bug?
Thanks for replies.
You've provided no proof of that.
PaulS:
The code printing free memory. Printed free memory is decrasing.
Remove "SD.open()" from setup and try this in loop:
list_files();
directory.close();
delay(2000);
Danois90:
list_files();
directory.close();
delay(2000);
No memory leak on this code.
You probably ought to follow all of the advice that you were given in your other thread before you try anything else.
Thanks for replies. I forgot directory.close(); line.
