arduino with serial rs232 ?
can you buy an arduino that does not have a virtual usb serial port - but with a real serial connector on the end ?
You used to be able to, but nobody did. So, they've been relegated to the what-used-to-be department.
If you felt the need for an obsolete, next-to-useless, out of date thingy, go to the thrift shops. However, you really needed one, I guess you can use the TX and RX pins and with a bit of tinkering make it serial, but that might require fooling with the bootloader, so...
You sure can. What kind of form factor?
Real connector on this 1284 based board.
3-pin header on this dual 328 based board, connect to pins 2-3-5 on a 9-pin connector.
some possible DIY setups.
http://www.scienceprog.com/alternatives-of-max232-in-low-budget-projects/
eBay is a good place to start.
I have purchased from this eBay store previously with good results: http://stores.ebay.com/AVRMEGASHOP They sell RS-232 Arduino compatible boards.
There are some caveats: not compatible with Arduino shields, no 3.3v capability.
Gadget999:
Like a Pro Mini with one of these?
