Arduino with SSC32
Hey all, Im new to these forums and just recieved my Duemilanove through the post. I am at the minute just doing some basic programs, altho I have plenty of experience programming in C++, but only in writing software not coding hardware.
I was just wondering, if I got an SSC32 what is the max number of servos I would b able to control using my Arduino? I have never played with servos before.
I am going to have a play with stepper motors next when I get paid but I do have a project in mind using servos.
Cheers
Hi Cyberstu,
I would say you can control up to 32 servos with the ssc-32 with what I read on the subject. But you can't use the Arduino 5V, you have to provide power from another source. Just don't forget to connect the grounds together (Arduino and ssc-32).
If someone has had experience with this board and the Arduino I'd be glad to hear a little, I'm interested in this board. :)
retxed68
Here is a website I found explaining how to control the ssc-32 with the Arduino:
http://robotics.nuvvo.com/lesson/7437-moving-servos-with-a-ssc-32-and-an-arduino
retxed68
I've got an ssc-32connected to my arduino. Simple connection, tx/rx, tx/rx, and gnd/gnd. The ssc-32 board itself could be powered off of the arduino +5v. The servos need their own ~6v power supply.
Sorry, but I’m amazed that you can identify that the SSC32 is what you want without also identifying that it controls 32 servos? ;D
SSC-32 Servo Controller:
http://www.lynxmotion.com/p-395-ssc-32-servo-controller.aspx
Microcontroller = Atmel ATMEGA168-20PU
EEPROM = 24LC32P (Required for 2.01GP)
Speed = 14.75 MHz
Internal Sequencer = 12 Servo Hexapod (Alternating Tripod)
Serial input = True RS-232 or TTL, 2400, 9600, 38.4k, 115.2k, N81
Outputs = 32 (Servo or TTL)
Inputs = 4 (Static or Latching, Analog or Digital)
Current requirements = 31mA
PC interface = DB9F
Microcontroller interface = Header posts
Servo control = Up to 32 servos plug in directly
Servo type supported = Futaba or Hitec
Servo travel range = 180°
Servo resolution = 1uS, .09°
Servo speed resolution = 1uS / Second
Servo motion control = Immediate, Timed, Speed or Synchronized.
PC board size = 3.0" x 2.3"
VS current capacity = 15 amps per side, 30 amps max
SSC-32 Firmware for the Atmega168 (v2) Onboard Chip:
http://www.lynxmotion.com/images/files/firmware/2-03XE.abl
SSC-32 Sequencer PC-Software:
http://www.lynxmotion.com/p-443-ssc-32-sequencer.aspx
SSC-32 Arm Control PC-Software:
http://www.lynxmotion.com/p-419-rios-ssc-32-arm-control-software.aspx
