I have my arduino set up to give me signal output when I give him signal input but can I program it to give signals in right time in the day. Exp. I want it to start my motor in exactly 8 PM. How can I make this?!
If you use the Arduino's built-in clock your time will drift by several minutes a day and will be lost completely if the power is ever lost. You should add a Real-Time Clock (RTC) which will keep accurate time like a quartz watch.
johnwasser:
boddah_cro:
tnx a lot! coding the clock input into arduino should't be a problem I suppose?
Adafruit always provides libraries and tutorials for their Arduino products. Check out the information they supply to see if the wiring is within your capabilities.
Tnx johnwasser but I'm a newbie so in adafruit library, I can only see how to setup the clock onto the display And I need how to make my Arduino do something in right time. Sorry.
Something like this will turn on the motor at 8 PM.
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
boolean MotorIsRunning = false;
void setup () {
Serial.begin(57600);
Wire.begin();
RTC.begin();
if (! RTC.isrunning()) {
Serial.println("RTC was NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(__DATE__, __TIME__));
Serial.println("RTC wfailed to start running");
while (true);
void loop () {
DateTime now = RTC.now();
// Start the motor at 8 PM (20:00)
if (now.hour() == 20 && !MotorIsRunning) {
// Add code here to start the motor
MotorIsRunning = true;
Serial.println(“RTC was NOT running!”);
RTC.adjust(DateTime(DATE, TIME));
Serial.println(“RTC wfailed to start running”);
while (true);
void loop () {
