Arduino with ZigBee
I have designed a network of three nodes which contains Micro controller, Storage and ZigBee for communication.
I am sending some random data from node.A to node.C through node.B.
While on node C or receiving end of the network I am getting the data in HEX form i.e
D,A,34,36,30,20,32,30,31,39,2F,39,2F,31,32,20,31,32,3A,34,39,3A,34
But I want to obtain it in simple text form which will look like
460 2019/9/12 12:49:04
460 is a random number and the remaining is its sending time and date
void data_receive()
  if (xbee_receive.available()>=21){
    for(int i=0;i<22;i++){
      incomingByte=xbee_receive.read();
      if(incomingByte==0x3A)
      digitalWrite(led,HIGH);
      Serial.print(incomingByte,HEX);
      Serial.print(",");
      delay(100);
      digitalWrite(led,LOW);
The LED is just for confermation of receiving data.
Please help me someone that how can I convert my data on receiving end back to simple ASCII char form.
it is coming in as bytes (characters) you are converting it to HEX yourself
      Serial.print(",");
incomingByte is a byte (or a char as you like) if you've sent it as chars thenSerial.print(incomingByte);should print them out again as such, in your case the data starts with A (or 0xA) which is 10 which is \n followed by D which is 13 which is \r and then... ah well.
