Arduino wont upload the sketch STK500
I have one of the same problems. Mine says:
Sketch uses 1136 bytes (3%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x6b
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x6b
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
TOPIC SPLIT
DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
What arduino? Do you have the right board selected? If it's a nano, have you tried the old bootloader option?
If it's an Uno WiFi Rev. 2, that is not the same as Uno WiFi. If it's a nano every/iot/33, that is not the same as a nano. For those boards, you need to install the appropriate board package via board manager.
