arduino works with windows 8.1, because the port is not detected, already installed the arduino program but I can not change port and the hardware is not detected when connected via usb....
You mean that is NOT working with Win8.1?
What version Ide are you using? What board type are you using?
Most common problem using Win 8.1 is needing 'signed' usb driver for the board type you are using. only the newer IDE have such drivers for newer board types.
my board is Arduino UNO R3, thank you very much for your collaboration
what you say in the message the solution is:
'signed' usb driver for the board arduino UNO. the newer IDE version, I HAVE THE VERSION 1.0.5-r2 for Windows, IM RUN OTHERS DRIVES FOR USB PORT AND WIN8.1 DISPLAY SAYS:
E0000228
he drivers for this device are not installed. (Code 28)
There are no compatible drivers for this device.
Armando123456:
E0000228
Then you are simply not following the instructions correctly. Reinstall the proper drive for the Uno board and all should work.
Armando123456:
u need to do some settings
go to device manager of ur pc and update usb drive which arduino is detecting
need assistance contact: mail.skullbucks@gmail.com
I'll CAN NOT RUN THE DRIVERS (dpinst-amd64) , WENT TRY TO UNZIP OLD_ARDUINO_DRIVERS I CANT[,
i have 64bits win8
