arduino +xampp +php
I wanna connect, arduino over xampp + php , i have already arduino code. which open web page from sd card but now how to open web page from xampp insted of sd card please help in arduino code.
bellow is arduino code.
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// size of buffer used to capture HTTP requests
#define REQ_BUF_SZ 40
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 4); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
File webFile;
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0; // index into HTTP_req buffer
// disable Ethernet chip
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
Serial.begin(9600); // for debugging
// initialize SD card
Serial.println("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
Serial.println("SUCCESS - SD card initialized.");
// check for index.htm file
if (!SD.exists("index.php")) {
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
pinMode(3, INPUT); // switch is attached to Arduino pin 3
pinMode(4, INPUT); // switch is attached to Arduino pin 4
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
// buffer first part of HTTP request in HTTP_req array (string)
// leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
if (req_index < (REQ_BUF_SZ - 1)) {
HTTP_req[req_index] = c; // save HTTP request character
req_index++;
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: keep-alive");
client.println();
// Ajax request
if (StrContains(HTTP_req, "ajax_switch")) {
// read switch state and send appropriate paragraph text
GetSwitchState(client);
else { // web page request
// send web page
webFile = SD.open("index.php"); // open web page file
if (webFile) {
while(webFile.available()) {
client.write(webFile.read()); // send web page to client
webFile.close();
// display received HTTP request on serial port
Serial.println(HTTP_req);
// reset buffer index and all buffer elements to 0
req_index = 0;
StrClear(HTTP_req, REQ_BUF_SZ);
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
// send the state of the switch to the web browser
void GetSwitchState(EthernetClient cl)
if (digitalRead(3)) {
cl.println("red");
else {
cl.println("green");
if (digitalRead(4)) {
cl.println("red");
else {
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
for (int i = 0; i < length; i++) {
str = 0;
    // searches for the string sfind in the string str
    // returns 1 if string found
    // returns 0 if string not found
    char StrContains(char *str, char *sfind)
  • char found = 0;*
  • char index = 0;*
  • char len;*
  • len = strlen(str);*
  • if (strlen(sfind) > len) {*
  • return 0;*
  • while (index < len) {*
  • if (str[index] == sfind[found]) {*
  • found++;*
  • if (strlen(sfind) == found) {*
  • return 1;*
  • else {*
  • found = 0;*
  • index++;*
  • return 0;*
    multi.ino (5.3 KB)
This should be all you need:
http://forum.arduino.cc/index.php?topic=452765.msg3134238#msg3134238
edit to suit your own needs/project.
Summary of files:
MySQL table set-up (will need to be updated to suit your needs)
PHP script to INSERT into a table
PHP script to QUERY a table
Arduino sketch to insert data
Arduino sketch to retrieve data
