Analog Inputs: A0 - A5, A6 - A11 (on digital pins 4, 6, 8, 9, 10, and 12). The Yún has 12 analog inputs, labeled A0 through A11, all of which can also be used as digital i/o. Pins A0-A5 appear in the same locations as on the Uno; inputs A6-A11 are on digital i/o pins 4, 6, 8, 9, 10, and 12 respectively. Each analog input provide 10 bits of resolution (i.e. 1024 different values).
Thanks for the quote!! However, it does not answer my question because my Yun analog pins are only reading 1000 different values and the quote says it should read 1024.
Jumper from the 3.3v pin to the AREF pin, read from analog pin connected to potentiometer and 3.3v pin
int analogPin = 3;
int val = 0;
Serial.begin(9600); // setup serial
analogReference(EXTERNAL);
val = analogRead(analogPin); // read the input pin
Serial.println(val); // debug value
