Arduino Yun and Uno comparison
i have simple interrupt code witch works great on arduino Uno board pins 2 and 3, if arduino Yun also has interrupts on pins 2 and 3 why that same code wont show same results, i know that two board use different controller. but INT0 and INT1 are the same.
Uno Yun
int1 pin3 int1 pin2
int0 pin2 int0 pin3
attachInterrupt(0, brojacA, RISING); //pin2
attachInterrupt(1, brojacB, RISING); //pin3
i just switch pins on Yun and instead of getting to count pulses from optical sensor on serial monitor i can only see values 0 and 65536
this is whole code
volatile unsigned int broji = 0;
pinMode(2, INPUT);
pinMode(3, INPUT);
//pin 2
//pin 3
Serial.println(broji);
void brojacA(){
  if(digitalRead(3) == LOW){
    broji++;
  }else{
    broji--;
void brojacB(){
  if(digitalRead(2) == LOW){
    broji--;
  }else{
    broji++;
if someone can help it will be much appreciated.
Filip88:
Uno Yun
int1 pin3 int1 pin2
int0 pin2 int0 pin3
this is whole code
pinMode(2, INPUT);
pinMode(3, INPUT);
//pin 2
//pin 3
void brojacA(){
    broji++;
  }else{
    broji--;
void brojacB(){
    broji--;
  }else{
    broji++;
It is 0200 hrs here and I will try it in the morning.
Which Tun are you using? Arduino.cc or Arduino.org Yun?
Which version of Arduino IDE are you using?
Operating system? Linux, Macosx or Windows ?
windows 10
i dont know if it is cc or org
IDK ver is 1.8.5
Hello,
I think you could use the function digitalPinToInterrupt(pin). It could work this way:
attachInterrupt(digitalPinToInterrupt(2), brojacA, RISING);
attachInterrupt(digitalPinToInterrupt(3), brojacA, RISING);
