Arduino Yun (as Client) TCP Communication Interface with NI LabVIEW (as Server)
Hi, I’m in need of help again to establish TCP communication through Arduino Yun as the Client to NI LabVIEW as the Server. I have here a slightly edited sample code for the Arduino Yun to act as the client, however I wasn’t able to connect the Arduino Yun with NI LabVIEW (as the Server).
Is the code correct? Thanks in advance. I need to solve this urgently.
#include <Bridge.h>
#include <YunClient.h>
YunClient client;
byte ip[] = {192,168,1,6};
int port = 255;
static boolean clientActive = false;
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
Bridge.begin();
digitalWrite(13, LOW);
client.connect(ip,port);
if (client.connected()) {
if(!clientActive)
Serial.println("New client connection.");
clientActive = true;
if(client.available()) {
Serial.print("From client: \"");
while(client.available())
Serial.print((char)client.read());
Serial.println("\"");
client.print("Hello");
else {
Serial.println("Cannot connect, retry...");
client.stop();
@Life_Learner,
please edit your message and add markups to it. This will make it easier for people to see your code, and copy it - if needed. See attached image.
TIA
Jesse
