Arduino Yun call function on server issue
Hello all, i just purchased a Yun a couple of days ago and I am trying to send a value to my .net application using wifi. When i upload the sketch nothing happens.
I have a function there that will enter a value to my database when called and return a json reply. Can someone take a look and provide some assistance. Thanks in advance.
Running process using Process class.
This sketch demonstrate how to run linux processes
using an Arduino Yún.
created 5 Jun 2013
by Cristian Maglie
This example code is in the public domain.
#include <Process.h>
// Initialize Bridge
Bridge.begin();
// Initialize Serial
// Wait until a Serial Monitor is connected.
while (!Serial);
// run various example processes
runCurl();
runCpuInfo();
// Do nothing here.
// The path to the server function is: http://subDomain.domain.com/cleanProcust_/arduinotest/2
void runCurl() {
// Launch "curl" command and get Arduino ascii art logo from the network
// curl is command line program for transferring data using different internet protocols
Process p; // Create a process and call it "p"
p.begin("curl"); // Process that launch the "curl" command
p.addParameter("http://subDomain.domain.com/cleanProcust_/arduinotest/"); // Add the URL parameter to "curl"
p.run(); // Run the process and wait for its termination
// Print arduino logo over the Serial
// A process output can be read with the stream methods
while (p.available() > 0) {
char c = p.read();
Serial.print(c);
// Ensure the last bit of data is sent.
Serial.flush();
Here is my app function:
Function arduinoTest() As JsonResult
Dim cleanproServicesJob As New cleanproServicesJob
' Dim routeCheck = db.cleanProRoutes.Single(Function(p) p.rowUUID = Id)
cleanproServicesJob.rowUUID = Guid.NewGuid
cleanproServicesJob.Service = "Arduino 4567"
' cleanproServicesJob.Category =
db.cleanproServicesJobs.AddObject(cleanproServicesJob)
db.SaveChanges()
Dim result = New With {.success = "True"}
Return Json(result, JsonRequestBehavior.AllowGet)
End Function
I found the problem, i moved the "runCurl" function on the next line after "Bridge.begin();" and it works.
its probably because you didnt open the serial monitor
while (!Serial);
waits until you do
