Arduino Yun - connection question
Hello. I have been using arduino yun for few days. Prevously i had arduino uno r3 and used it to read analogs via USB.
My question is :
Is there any way to connect the arduino yun with the laptop using ip and port (LAN) ?
I am using VisualStudio2010 and would like to receive a data from the yun (analog) in my program.
thanks for your help
http://arduino.cc/en/Tutorial/Bridge
http://myArduinoYun.local/arduino/digital/13 : calls digitalRead(13);
http://myArduinoYun.local/arduino/digital/13/1 : calls digitalWrite(13,1);
http://myArduinoYun.local/arduino/analog/9/123 : analogWrite(9,123);
http://myArduinoYun.local/arduino/analog/2 : analogRead(2);
Consume RESt API from .NET
Thanks for your answer sonnyyu.
Unfortunately It does not solve my problem. :frowning: The point is that I need to receive data from the Arduino YUN through the ip using PC programm.
Example:
Arduino YUN ( ip : 192.168.1.200 ) ---------sending analogRead(x) --> Visual Studio_PC( ip : 192.168.1.999 )
Visual Studio_PC( ip : 192.168.1.199 ) -------- ok YUN thanks ! -----> Arduino YUN ( ip : 192.168.1.200 )
I do not want to use any of the http browsers to read the analog, unless it is the last chance to get any info from the YUN.
I would appreciate any code explaining how to send a data from the Arduino YUN to specific adress IP.
Thank you for your help :slight_smile:
One click away.
 var client = new HttpClient();
var response = client.Get("http://myArduinoYun.local/arduino/analog/2");
analogRead(2).
If You would like to setup RESt Service API at .NET, and Consume RESt API from Yun.
Consume .NET RESt API from Arduino
Yun HTTP Client
  HttpClient client;
  client.get(dotnetwebserviceURI);
  while (client.available()) {
    char c = client.read();
    Serial.print(c);
  Serial.flush();
  delay(5000);
Thank you sonnyyu for your replay. Your post was very helpful. I managed to get a flow data through the WiFi.
Nevertheless, I would have one more question connected with the the data transmission speed.
While Arduino gets : http://arduino.local/arduino/analog/1
it returns value of the analogs in the format : 1024,1024,1024,1024,1024 ( client.print(values) )
In my C# application I am downloading http text and breaking this up text for 5 peaces.
string value = client.DownloadString("http://arduino.local/arduino/analog/1");
The problem is that it takes too much time to get this data from the http. Wifi signal strength is 98%.
Estimated time to get the data from http is 300-500ms. In comparison with the USB data flow - which takes 1,3 ms - the Arduino YUN WiFi speed is very poor.
What would You recon to make it faster. Thank You for your help. :smiley: :smiley: :smiley: :smiley:
My guess the slowness come from bridge, however to reach response time as low as 1 ms the Web Restful service will be fail. Since it build on http protocol, it is stateless protocol.
Solution:
WebSockets are a bi-directional, full-duplex, persistent connection from a client to a server. Once a WebSocket connection is established the connection stays open until the client or server decides to close this connection. Node.js uses an event-driven, non-blocking I/O model that makes it lightweight and efficient as well as fast.
http://forum.arduino.cc/index.php?topic=215615.msg1580707#msg1580707
Node.js support from Microsoft
Thank You sonnyyu for your help.
Your idea will definitely do the job.
Node.js looks like a python programming.
I am using quite advanced c# application and switching into the different application would be a daunting task.
I have already created app using socket and ip commnuication.
Do you have any arduino yun server example, how to send some data using ip and port ? Or how to work with the websockets ? ( sending and receiving data )
sealima:
sonnyyu:
Node.js is a platform built on Chrome's JavaScript runtime V8 .
sealima:
not standard socket app but WebSockets app.
sealima:
Ha, 2 mouse clicks away from Long lasting connection between Yún and PC - #3 by sonnyyu - Arduino Yún - Arduino Forum.
http://linino.org/doku.php?id=wiki:nodejs
