Salva ragazzi...premetto che prima di scrivere qui ho letto altri Topic ma nn sono riuscito a capire come risolvere il problema. allora io sto facendo delle prove con il file example Bridge con arduino Yun. quando mi ritrovo a mettere nel browser: http://myArduinoYun.local/arduino/digital/13, esce :
Could not connect to YunServer 146 Connection refused.
l'opzione Rest è impostata su Open, ho sostituito server.listenOnLocalhost(); con server.noListenOnLocalhost(); ho spento e riacceso arduino. non so cosa fare...datemi una dritta per favore.
Arduino Yún Bridge example
This example for the Arduino Yún shows how to use the
Bridge library to access the digital and analog pins
on the board through REST calls. It demonstrates how
you can create your own API when using REST style
calls through the browser.
Possible commands created in this shetch:
* "/arduino/digital/13" -> digitalRead(13)
* "/arduino/digital/13/1" -> digitalWrite(13, HIGH)
* "/arduino/analog/2/123" -> analogWrite(2, 123)
* "/arduino/analog/2" -> analogRead(2)
* "/arduino/mode/13/input" -> pinMode(13, INPUT)
* "/arduino/mode/13/output" -> pinMode(13, OUTPUT)
This example code is part of the public domain
http://arduino.cc/en/Tutorial/Bridge
#include <Bridge.h>
#include <YunServer.h>
#include <YunClient.h>
// Listen to the default port 5555, the Yún webserver
// will forward there all the HTTP requests you send
YunServer server;
// Bridge startup
pinMode(13, OUTPUT);
digitalWrite(13, LOW);
Bridge.begin();
digitalWrite(13, HIGH);
// Listen for incoming connection only from localhost
// (no one from the external network could connect)
server.begin();
// Get clients coming from server
YunClient client = server.accept();
// There is a new client?
if (client) {
// Process request
process(client);
// Close connection and free resources.
client.stop();
delay(50); // Poll every 50ms
void process(YunClient client) {
// read the command
String command = client.readStringUntil('/');
// is "digital" command?
if (command == "digital") {
digitalCommand(client);
// is "analog" command?
if (command == "analog") {
analogCommand(client);
// is "mode" command?
if (command == "mode") {
modeCommand(client);
void digitalCommand(YunClient client) {
int pin, value;
// Read pin number
pin = client.parseInt();
// If the next character is a '/' it means we have an URL
// with a value like: "/digital/13/1"
if (client.read() == '/') {
value = client.parseInt();
digitalWrite(pin, value);
else {
value = digitalRead(pin);
// Send feedback to client
client.print(F("Pin D"));
client.print(pin);
client.print(F(" set to "));
client.println(value);
// Update datastore key with the current pin value
String key = "D";
key += pin;
Bridge.put(key, String(value));
void analogCommand(YunClient client) {
int pin, value;
// Read pin number
// with a value like: "/analog/5/120"
// Read value and execute command
analogWrite(pin, value);
client.print(pin);
client.print(F(" set to analog "));
String key = "D";
key += pin;
else {
// Read analog pin
value = analogRead(pin);
client.print(F("Pin A"));
client.print(pin);
client.print(F(" reads analog "));
String key = "A";
key += pin;
void modeCommand(YunClient client) {
int pin;
// Read pin number
// If the next character is not a '/' we have a malformed URL
if (client.read() != '/') {
client.println(F("error"));
return;
String mode = client.readStringUntil('\r');
if (mode == "input") {
pinMode(pin, INPUT);
client.print(pin);
client.print(F(" configured as INPUT!"));
return;
if (mode == "output") {
pinMode(pin, OUTPUT);
client.print(pin);
client.print(F(" configured as OUTPUT!"));
return;
client.print(F("error: invalid mode "));
client.print(mode);
