Arduino YUN - curl not working
I have read a ton of messages trying to find my answer but no luck. Can someone give me advice on this.
I have a need to call a web page that will pass the device address and issues an alert to our emergency responders. I have a YUN that I want use curl and pass a URL. I have used the following code
Basically the code calls this function, makeEmergencyCall and the function sets up a process p and calls the URL. The issue is if I open a terminal session to the YUN with Putty and copy and paste my call onto the command line (ie curl -k "http://10.127....." the web page is called as expected.
But when I call the same web url using curl and parameters, it does not work and no errors are reported.
void makeEmergencyCall() {
Console.println("Sending call via web page...");
Process p;
p.begin("curl");
p.addParameter("-k");
String myURL = "http://10.127.1.120:56500/XMII/Illuminator?QueryTemplate=Plastek/EmergencyResponse/xAc_receive_emergency_button&Param.1=10.127.120.79&j_user=miiarduino&j_password=plastekMII1&ContentType=text/html";
p.addParameter(myURL);
p.run();
while (p.available()>0) {
char c = p.read();
Console.print(c);
// Ensure the last bit of data is sent.
Console.flush();
p.close();
