I tried to join them but once I read one by changing loop some things I read just the other
How can I join this program
#include <Bridge.h>
#include <YunServer.h>
#include <YunClient.h>
// Listen to the default port 5555, the Yún webserver
// will forward there all the HTTP requests you send
YunServer server;
// Bridge startup
pinMode(13, OUTPUT);
digitalWrite(13, LOW);
Bridge.begin();
digitalWrite(13, HIGH);
// Listen for incoming connection only from localhost
// (no one from the external network could connect)
server.listenOnLocalhost();
server.begin();
// Get clients coming from server
YunClient client = server.accept();
// There is a new client?
if (client) {
// Process request
process(client);
// Close connection and free resources.
client.stop();
delay(50); // Poll every 50ms
void process(YunClient client) {
// read the command
String command = client.readStringUntil('/');
// is "digital" command?
if (command == "digital") {
digitalCommand(client);
// is "analog" command?
if (command == "analog") {
analogCommand(client);
// is "mode" command?
if (command == "mode") {
modeCommand(client);
void digitalCommand(YunClient client) {
int pin, value;
// Read pin number
pin = client.parseInt();
// If the next character is a '/' it means we have an URL
// with a value like: "/digital/13/1"
if (client.read() == '/') {
value = client.parseInt();
digitalWrite(pin, value);
else {
value = digitalRead(pin);
// Send feedback to client
client.print(F("Pin D"));
client.print(pin);
client.print(F(" set to "));
client.println(value);
// Update datastore key with the current pin value
String key = "D";
key += pin;
Bridge.put(key, String(value));
void analogCommand(YunClient client) {
int pin, value;
// Read pin number
// with a value like: "/analog/5/120"
// Read value and execute command
analogWrite(pin, value);
client.print(pin);
client.print(F(" set to analog "));
String key = "D";
key += pin;
else {
// Read analog pin
value = analogRead(pin);
client.print(F("Pin A"));
client.print(pin);
client.print(F(" reads analog "));
String key = "A";
key += pin;
void modeCommand(YunClient client) {
int pin;
// Read pin number
// If the next character is not a '/' we have a malformed URL
if (client.read() != '/') {
client.println(F("error"));
return;
String mode = client.readStringUntil('\r');
if (mode == "input") {
pinMode(pin, INPUT);
client.print(pin);
client.print(F(" configured as INPUT!"));
return;
if (mode == "output") {
pinMode(pin, OUTPUT);
client.print(pin);
client.print(F(" configured as OUTPUT!"));
return;
client.print(F("error: invalid mode "));
client.print(mode);
with this so that work simultaneously?
#include "DHT.h"
#include <Bridge.h>
#define DHTPIN 2
#define DHTTYPE DHT11
YunServer server;
DHT dht(DHTPIN, DHTTYPE);
int h, t;
Bridge.begin();
server.begin();
dht.begin();
h = dht.readHumidity();
t = dht.readTemperature();
if (client) {
process(client);
client.stop();
delay(50);
String command = client.readStringUntil('\r');
if (command == "termo") {
temp(client);
if (command == "idro") {
idro(client);
void temp(YunClient client) {
if (isnan(t)) {
client.print(F("Error"));
client.print(t);
void idro(YunClient client) {
if (isnan(t)) {
client.print(h);
The problem I think is this but these are not know how to solve it:
The reading command for the temperature brings this string
String command = client.readStringUntil ('\ r');
Instead the peo commands for the bridge port this
String command = client.readStringUntil ('/');
Maybe the problem is in the client because if I create two processes and two clients one works well rl other does not need to click Type 3 4 times to start the command.
If it helps put the program I joined I gives me problems
