Hi, I'm currently working with an Arduino yun and a Huawei E173 dongle. Apparently everything goes well, but after a few hours the arduino yun stops communicating with the dongle and the only way to solve the problem is to unplug and plug the dongle.
For now I have done the following:
- I configured the dongle according to the guide: [OpenWrt Wiki] Use 3g/UMTS USB Dongle for WAN connection and some youtube videos.
- When the dongle works I have internet access and the SD card
/mnt/sda1
or/mnt/sdb1
(random). I can also connect and disconnect the dongle using theifup wan-3g
/ifdown wan3-g
command (wan-3g is the dongle network) and it works. - When the connection fails, I do not have access to Internet or SD card.
- When I run
ifdown wan-3g
thenifup wan-3g
the network does not get up. - The data and energy line are separate. When I re-plug the data line the problem is solved, but not when I re-plug the power line.
- I tried using the
lsusb
command and thenusbreset 001/0XX
but it does not solve the problem. - I tried restarting the network, but it did not fix the problem
I would appreciate if someone could help me to solve this problem or some idea of connecting and reconnecting the dongle by commands
Thanks.
