Arduino Yun don't create wifi network
Hello guys. I'm trying to get started with arduino Yun. According to the tutorials, the Yun should create a wifi network where I would've to connect. It doesn't appera. beginner's guide recommends to press the WLAN RST for 5 seconds but less than 30 seconds... Nothing happens. Try pressing WLAN RST for more than 1 minute, nothing happens. The guide says that when you press WLAN RST, the WLAN led should turn on. But it never turns on. Any help please? Thank you very much.
The arduino official page says
NB : In some countries, it is prohibited to sell WiFi enabled devices without government approval. While waiting for proper certification, some local distributors are disabling WiFi functionality. Check with your dealer before purchasing a Yún if you believe you may live in such a country. If you wish to disable WiFi, run this sketch. For more information, refer to this forum post.
Sent me to this forum
http://forum.arduino.cc/index.php?topic=189105.0
In the forum it says how to disable de wifi, any ideas on how to enable it using the code in the forum?
Are you waiting long enough for the Linux side of the Yun to boot? It takes at least a minute for Linux to boot up and for the WiFi network to start up. One of the last boot actions is to turn on the white USB LED - be sure to wait for that to happen. In addition, any presses of the WLAN RST button are not recognized until Linux is fully booted up. Finally, if you successfully accomplish a WLAN RST button press, it can take many minutes of processing and rebooting before the operation is complete. Patience is necessary. It seems that the documentation never mentions how long some of these operations can take.
Have you tried a wired Ethernet connection? Can you access the configuration web pages through Ethernet? (After waiting for it to boot up, of course.)
Try connecting the USB port to your computer, and load the YunSerialTerminal example sketch. Connect to the Yun with the Serial Monitor, then press the YUN RST button. You will see a long stream of Linux boot messages. There may be long gaps when nothing is output. Wait several minutes for all of the Linux messages to be output, until Linux is fully booted and nothing has been printed for about a minute. Then copy all of the output and paste it here - that will let us see if anything is going wrong while Linux boots.
I have a similar problem.
Attachment traces in two post from YunSerialTerminal (The message exceeds the maximum allowed length (9000 characters)) :
U-Boot 1.1.4-linino-gca1b422d-dirty (Sep 15 2014 - 04:07:17)
Linino Board (ar9331) U-boot
DRAM: 64 MB
Top of RAM usable for U-Boot at: 84000000
Reserving 217k for U-Boot at: 83fc8000
Reserving 192k for malloc() at: 83f98000
Reserving 44 Bytes for Board Info at: 83f97fd4
Reserving 36 Bytes for Global Data at: 83f97fb0
Reserving 128k for boot params() at: 83f77fb0
Stack Pointer at: 83f77f98
Now running in RAM - U-Boot at: 83fc8000
Flash Manuf Id 0xef, DeviceId0 0x40, DeviceId1 0x18
flash size 16777216, sector count = 256
Flash: 16 MB
In: serial
Out: serial
Err: serial
Net: eth0: b4:21:8a:00:00:00
eth1: b4:21:8a:00:00:01
eth0, eth1
autoboot in 4 seconds (stop with 'lin')...
Booting image at 9fea0000 ...
Image Name: MIPS OpenWrt Linux-3.3.8
Created: 2014-11-14 8:00:46 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 1185448 Bytes = 1.1 MB
Load Address: 80060000
Entry Point: 80060000
Verifying Checksum at 0x9fea0040 ...OK
Uncompressing Kernel Image ... OK
No initrd
Transferring control to Linux (at address 80060000) ...
Giving linux memsize in bytes, 67108864
Starting kernel ...
[ 0.000000] Linux version 3.3.8 (jenkins@jenkins) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Fri Nov 14 08:57:34 CET 2014
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00004000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00004000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: board=Yun console=ttyATH0,250000 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env)ro,14656k(rootfs),1280k(kernel),64k(nvram),64k(art),15936k@0x50000(firmware) rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 60936k/65536k available (2565k kernel code, 4600k reserved, 650k data, 180k init, 0k highmem)
[ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.080000] NET: Registered protocol family 16
[ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
[ 0.090000] MIPS: machine is Arduino Yun
[ 0.530000] Setting DogStick2 GPIO
[ 0.550000] bio: create slab at 0
[ 0.550000] SCSI subsystem initialized
[ 0.560000] usbcore: registered new interface driver usbfs
[ 0.560000] usbcore: registered new interface driver hub
[ 0.560000] usbcore: registered new device driver usb
[ 0.570000] Switching to clocksource MIPS
[ 0.570000] NET: Registered protocol family 2
[ 0.570000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.580000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.580000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.580000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.580000] TCP reno registered
[ 0.580000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.590000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.590000] NET: Registered protocol family 1
[ 0.610000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.610000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.620000] msgmni has been set to 119
[ 0.620000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[ 0.620000] io scheduler noop registered
[ 0.630000] io scheduler deadline registered (default)
[ 0.630000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.640000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) i{ a AR933X UART
[ 0.640000] console [ttyATH0] enabled, bootconsole disabled
[ 0.650000] m25p80 spi0.0: found w25q128, expected m25p80
[ 0.650000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.650000] 7 cmdlinepart partitions found on MTD device spi0.0
[ 0.660000] Creating 7 MTD partitions on "spi0.0":
[ 0.660000] 0x000000000000-0x000000040000 : "u-boot"
[ 0.660000] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.670000] 0x000000050000-0x000000ea0000 : "rootfs"
[ 0.670000] mtd: partition "rootfs" set to be root filesystem
[ 0.670000] mtd: partition "rootfs_data" created automatically, ofs=7B0000, len=6F0000
[ 0.680000] 0x0000007b0000-0x000000ea0000 : "rootfs_data"
[ 0.680000] 0x000000ea0000-0x000000fe0000 : "kernel"
[ 0.680000] 0x000000fe0000-0x000000ff0000 : "nvram"
[ 0.690000] 0x000000ff0000-0x000001000000 : "art"
[ 0.690000] 0x000000050000-0x000000fe0000 : "firmware"
[ 0.710000] ag71xx_mdio: probed
[ 0.720000] eth0: Atheros AG71xx at 0xba000000, irq 5
[ 1.270000] eth0: Found an AR7240/AR9330 built-in switch
[ 2.300000] eth1: Atheros AG71xx at 0xb9000000, irq 4
[ 2.850000] ag71xx ag71xx.0: eth1: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
[ 2.850000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.850000] ehci-platform ehci-platform: Generic Platform EHCI Controller
[ 2.860000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[ 2.890000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 2.910000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 2.910000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.910000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.910000] usb usb1: Product: Generic Platform EHCI Controller
[ 2.920000] usb usb1: Manufacturer: Linux 3.3.8 ehci_hcd
[ 2.920000] usb usb1: SerialNumber: ehci-platform
[ 2.920000] hub 1-0:1.0: USB hub found
[ 2.920000] hub 1-0:1.0: 1 port detected
[ 2.930000] Initializing USB Mass Storage driver...
[ 2.930000] usbcore: registered new interface driver usb-storage
[ 2.930000] USB Mass Storage support registered.
[ 2.930000] input: gpio-keys-polled as /devices/platform/gpio-keys-polled/input/input0
[ 2.940000] sdhci: Secure Digital Host Controller Interface driver
[ 2.940000] sdhci: Copyright(c) Pierre Ossman
[ 2.940000] usbcore: registered new interface driver ushc
[ 2.940000] TCP cubic registered
[ 2.950000] NET: Registered protocol family 17
[ 2.950000] Bridge firewalling registered
[ 2.950000] 8021q: 802.1Q VLAN Support v1®8
[ 2.960000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[ 2.960000] Freeing unused kernel memory: 180k freed
[ 3.260000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 3.460000] usb 1-1: New USB device found, idVendor=058f, idProduct=6254
[ 3.460000] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.470000] usb 1-1: Product: USB2.0Hub
[ 3.550000] hub 1-1:1.0: USB hub found
[ 3.550000] hub 1-1:1.0: 4 ports detected
[ 3.960000] usb 1-1.4: new high-speed USB device number 3 using ehci-platform
[ 4.100000] usb 1-1.4: New USB device found, idVendor=058f, idProduct=6366
[ 4.110000] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.110000] usb 1-1.4: Product: Mass Storage Device
[ 4.110000] usb 1-1.4: Manufacturer: Generic
[ 4.110000] usb 1-1.4: SerialNumber: 058F0O1111B1
[ 4.260000] scsi0 : usb-storage 1-1.4:1.0
[ 5.010000] Error: Driver 'gpio-keys-polled' is already registered, aborting...
[ 5.260000] scsi 0:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
  • preinit -
  • preinit -
    Press the [f] key and hit [enter] to enter failsafe mode
  • regular preinit -
    [ 9.570000] JFFS2 notice: (526) jffs2_build_xattr_subsystem: complete building xattr subsystem, 3 of xdatum (1 unchecked, 2 orphan) and 39 of xref (0 dead, 28 orphan) found.
    [ 11.440000] sd 0:0:0:0: [sda] 3911680 512-byte logical blocks: (2.00 GB/1.86 GiB)
    [ 11.450000] sd 0:0:0:0: [sda] Write Protect is off
    [ 11.450000] sd 0:0:0:0: [sda] No Caching mode page present
    [ 11.450000] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [ 11.460000] sd 0:0:0:0: [sda] No Caching mode page present
    [ 11.460000] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [ 11.460000] sda:
    [ 11.470000] sd 0:0:0:0: [sda] No Caching mode page present
    [ 11.470000] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [ 11.470000] sd 0:0:0:0: [sda] Attached SCSI removable disk
    switching to jffs2
  • init -
Please press Enter to activate this console. [ 32.250000] SQUASHFS error: xz_dec_run error, data probably corrupt
[ 32.250000] SQUASHFS error: squashfs_read_data failed to read block 0x223042
[ 32.260000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 32.260000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 32.270000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 32.270000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 32.280000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 32.280000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 37.740000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[ 37.750000] Backport generated by backports.git backports-20140320-37-g5c33da0
[ 37.920000] cfg80211: Calling CRDA to update world regulatory domain
[ 37.930000] cfg80211: World regulatory domain updated:
[ 37.930000] cfg80211: DFS Master region: unset
[ 37.930000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 37.930000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 37.940000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 37.940000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 37.940000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 37.950000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 37.950000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 38.810000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[ 38.820000] cfg80211: Calling CRDA for country: US
[ 38.820000] cfg80211: Regulatory domain changed to country: US
[ 38.820000] cfg80211: DFS Master region: FCC
[ 38.820000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 38.830000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 38.830000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 1700 mBm), (N/A)
[ 38.830000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2300 mBm), (0 s)
[ 38.840000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 38.840000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 39.270000] NTFS driver 2.1.30 [Flags: R/O MODULE].
[ 39.310000] Error: Driver 'gpio-keys-polled' is already registered, aborting...
[ 39.330000] loop: module loaded
[ 39.470000] PPP generic driver version 2.4.2
[ 39.520000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 39.640000] NET: Registered protocol family 24
[ 39.680000] nf_conntrack version 0.5.0 (954 buckets, 3816 max)
[ 40.120000] i2c /dev entries driver
[ 40.160000] Linux video capture interface: v2.00
[ 40.280000] fuse init (API version 7.18)
[ 44.530000] SQUASHFS error: xz_dec_run error, data probably corrupt
[ 44.530000] SQUASHFS error: squashfs_read_data failed to read block 0x223042
[ 44.540000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 44.540000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 44.550000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 44.550000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 45.070000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 45.080000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 45.430000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 45.440000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 50.660000] SQUASHFS error: xz_dec_run error, data probably corrupt
[ 50.660000] SQUASHFS error: squashfs_read_data failed to read block 0x223042
[ 50.660000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 50.670000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 50.700000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 50.700000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 50.730000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 50.740000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 53.410000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 53.410000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 53.450000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 53.450000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 53.510000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 53.510000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 56.560000] SQUASHFS error: xz_dec_run error, data probably corrupt
[ 56.560000] SQUASHFS error: squashfs_read_data failed to read block 0x223042
[ 56.560000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 56.570000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 56.590000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 56.600000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 56.620000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 56.620000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 63.830000] SQUASHFS error: xz_dec_run error, data probably corrupt
[ 63.830000] SQUASHFS error: squashfs_read_data failed to read block 0x223042
[ 63.830000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 63.840000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 63.840000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 64.600000] SQUASHFS error: xz_dec_run error, data probably corrupt
[ 64.610000] SQUASHFS error: squashfs_read_data failed to read block 0x223042
[ 64.610000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 64.610000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 64.640000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 64.640000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 64.660000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 64.670000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 68.970000] SQUASHFS error: xz_dec_run error, data probably corrupt
[ 68.970000] SQUASHFS error: squashfs_read_data failed to read block 0x223042
[ 68.980000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 68.980000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 68.990000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 69.130000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 69.130000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 69.140000] SQUASHFS error: Unable to read page, block 223042, size 13468
[ 69.150000] SQUASHFS error: Unable to read fragment cache entry [223042]
[ 69.150000] SQUASHFS error: Unable to read page, block 223042, size 13468
I repaired it!
http://forum.arduino.cc/index.php?topic=419067.0
