Arduino Yun Flash
Hello
how can I restore the Arduino Yun.
I tried the following
http://arduino.cc/en/Tutorial/YunUBootReflash #. UwpPs4V5_Yc
However, I get the following page when I enter the IP of Yun
  /\__\      ___        /\__\          ___        /\__\         /\  \
  /:/  /       /::\__\  /:/|:|  |__      /::\__\  /:/|:|  |__   /:/  \:\  \
 /:/__/     __/:/\/__/ /:/ |:| /\__\  __/:/\/__/ /:/ |:| /\__\ /:/__/ \:\__\
 \:\  \    /\/:/  /    \/__|:|/:/  / /\/:/  /    \/__|:|/:/  / \:\  \ /:/  /
  \:\  \   \::/__/         |:/:/  /  \::/__/         |:/:/  /   \:\  /:/  /
   \:\  \   \:\__\         |::/  /    \:\__\         |::/  /     \:\/:/  /
    \:\__\   \/__/         /:/  /      \/__/         /:/  /       \::/  /
     \/__/                 \/__/                     \/__/         \/__/
            _______                     ________        __
           |       |.-----.-----.-----.|  |  |  |.----.|  |_
           |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
           |_______||   __|_____|__|__||________||__|  |____|
                    |__| W I R E L E S S   F R E E D O M
root@(none):/# picocom-b 115200 / dev/ttyACM0
root@(none):/# r
root@(none):/# root
root@(none):/# cd mmc
root@(none):/# help
Built-in commands:
        . : [ [[ alias bg break cd chdir command continue echo eval exec
        exit export false fg getopts hash help jobs kill let local printf
        pwd read readonly return set shift source test times trap true
        type ulimit umask unalias unset wait
root@(none):/# :/ usr / bin #. / Reset-zu-Werk-sowieso
root@(none):/#  usr / bin #.
root@(none):/#  usr
root@(none):/#
Look like you have terminal access.
Plan A: Reset to factory default.
/usr/bin/reset-to-factory-anyway
power cycle.
Plan B: Upgrading Using the Terminal
You might need few time power cycle.
