First off the thing is, i don't have an internet connection on the borad, can i the use the "Twilio sketch"...
I am using it to restart some internet equipment, and measure a temperature, and if i cant communicate with the equipment, the internet connection is lost some where, and need a restart to work again, and a gsm modul, will work, i guess and hope.
The Gsm Shield pluged direct on the Yün
and
The code i use is as following...
SMS sender
This sketch, for the Arduino GSM shield,sends an SMS message
you enter in the serial monitor. Connect your Arduino with the
GSM shield and SIM card, open the serial monitor, and wait for
the "READY" message to appear in the monitor. Next, type a
message to send and press "return". Make sure the serial
monitor is set to send a newline when you press return.
Circuit:
- GSM shield
- SIM card that can send SMS
created 25 Feb 2012
by Tom Igoe
This example is in the public domain.
http://arduino.cc/en/Tutorial/GSMExamplesSendSMS
// Include the GSM library
#include <GSM.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("SMS Messages Sender");
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while(notConnected)
if(gsmAccess.begin(PINNUMBER)==GSM_READY)
notConnected = false;
Serial.println("Not connected");
Serial.println("GSM initialized");
Serial.print("Enter a mobile number: ");
char remoteNum[20]; // telephone number to send sms
readSerial(remoteNum);
Serial.println(remoteNum);
// sms text
Serial.print("Now, enter SMS content: ");
char txtMsg[200];
readSerial(txtMsg);
Serial.println("SENDING");
Serial.println("Message:");
Serial.println(txtMsg);
// send the message
sms.beginSMS(remoteNum);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nCOMPLETE!\n");
Read input serial
int readSerial(char result[])
int i = 0;
while(1)
while (Serial.available() > 0)
char inChar = Serial.read();
if (inChar == '\n')
result = '\0';
- Serial.flush();*
- return 0;*
- if(inChar!='\r')*
_ result = inChar;_
* i++;*
[/quote]
The serial monitor only writes "SMS Messages Sender"
I am using a SIM card like the on from my mobile Phone, and i live in Denmark, and think that the frekvens should be okay..
No Pin code is neede
The tele-phone company is TELIA
