I played with Arduino Yun Mini for a while. My first feeling is that the Ar9331 Linux Wifi module boot up time is very long, a little more than 1 minutes.
Anybody has experience to cut this time down?
Arduino Yun Mini doesn't have USB, Ethernet adapter board. I am thinking maybe some boot up script can be deleted. Is it possible to cut this time down to around 30 seconds?
Thanks,
nick
nickyang:
Thanks,
nick
@nickyang,
On #1, Boot time on the Arduino Yun is two (2) to eight ( 8 ) minutes.
On #2, everyone.
On #3, The Arduino Yun Mini has a mini USB. That is used for power and the serial port to the device.
On #4, no.
Advice, Read the docs for the Arduino Yun.
Jesse
The Yun is running on openwrt - Linux.
10 ways to make Linux boot faster
#1: Disable unnecessary services
#2: Disable unnecessary kernel modules
#3: Use a lightweight window manager instead of GNOME or KDE
#4: Use a text-based login instead of a graphical login
#5: Use a lighter-weight distribution
#6: Use an OpenBIOS
#7: Avoid dhcp
#8: If you can spare it, get rid of hotplug
#9: If you are REALLY daring, you could give initng a try
#10: Use a hack with Debian
#7: Avoid dhcp:
Change wifi to static ip
Set static ip at wan (ethernet port)
nickyang:
Upgrade Openwrt Version version from Attitude Adjustment to Chaos Calmer will cut boot time down to 26 seconds
Openwrt Version:
- Attitude Adjustment
- Barrier Breaker
- Chaos Calmer
@All,
some of you may recall this ad-hoc poll we did a few months ago.
Yun Boot time after hitting [YUN RST] averages 1:02
http://forum.arduino.cc/index.php?topic=323687.0
Jesse
Upgrade to faster CPU, Yun has AR9331 (400Mhz). The AR9344 (600Mhz) boots faster.
