system
December 30, 2013, 9:59pm
1
Salve
non riesco a montare la micro SD, se invio il comando dmesg questo è il risultato:
[ 389.070000] sda: detected capacity change from 255852544 to 0
[ 526.500000] sd 0:0:0:0: [sda] 3911680 512-byte logical blocks: (2.00 GB/1.86 GiB)
[ 526.500000] sd 0:0:0:0: [sda] No Caching mode page present
[ 526.510000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 526.590000] sd 0:0:0:0: [sda] No Caching mode page present
[ 526.590000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 526.590000] sda:
non conosco il mondo Linux e non saprei dove cercare.
La scheda e' formattata FAT32 ed ha una cartella arduino con una sottocartella www
pictux
December 31, 2013, 1:22am
2
Ciao,
La sd dovrebbe venire montata in automatico.
Hai dato un'occhiata qui?
http://playground.arduino.cc/Hardware/Yun#using_sd_card
Dopo il dmesg, per vedere se effettivamente montata, puoi digitare
mount
system
December 31, 2013, 2:21pm
3
se faccio mount mi appare questo:
root@Arduino:~# mount
rootfs on / type rootfs (rw)
/dev/root on /rom type squashfs (ro,relatime)
proc on /proc type proc (rw,noatime)
sysfs on /sys type sysfs (rw,noatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime,size=30568k)
tmpfs on /dev type tmpfs (rw,noatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,noatime,mode=600)
/dev/mtdblock3 on /overlay type jffs2 (rw,noatime)
overlayfs:/overlay on / type overlayfs (rw,noatime,lowerdir=/,upperdir=/overlay)
debugfs on /sys/kernel/debug type debugfs (rw,noatime)
system
December 31, 2013, 2:23pm
4
se provo a montare anche una chiavetta usb ( da 32 Gb) e faccio dmesg ecco output:
[ 11.780000] sd 0:0:0:0: [sda] 3911680 512-byte logical blocks: (2.00 GB/1.86 GiB)
[ 11.780000] sd 0:0:0:0: [sda] Write Protect is off
[ 11.790000] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 11.790000] sd 0:0:0:0: [sda] No Caching mode page present
[ 11.790000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 11.800000] sd 0:0:0:0: [sda] No Caching mode page present
[ 11.800000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 11.800000] sda:
[ 11.810000] sd 0:0:0:0: [sda] No Caching mode page present
[ 11.810000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 11.810000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 39.230000] Compat-drivers backport release: compat-drivers-2013-01-21-1
[ 39.230000] Backport based on wireless-testing.git master-2013-02-22
[ 39.230000] compat.git: wireless-testing.git
[ 39.270000] cfg80211: Calling CRDA to update world regulatory domain
[ 39.270000] cfg80211: World regulatory domain updated:
[ 39.270000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 39.270000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 39.280000] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 39.280000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 39.280000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 39.290000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 40.070000] ath: EEPROM regdomain: 0x0
[ 40.070000] ath: EEPROM indicates default country code should be used
[ 40.070000] ath: doing EEPROM country->regdmn map search
[ 40.070000] ath: country maps to regdmn code: 0x3a
[ 40.070000] ath: Country alpha2 being used: US
[ 40.070000] ath: Regpair used: 0x3a
[ 40.070000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 40.080000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[ 40.090000] cfg80211: Calling CRDA for country: US
[ 40.090000] cfg80211: Regulatory domain changed to country: US
[ 40.090000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 40.090000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
[ 40.100000] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
[ 40.100000] cfg80211: (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 40.100000] cfg80211: (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 40.110000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 40.110000] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
[ 40.470000] NTFS driver 2.1.30 [Flags: R/O MODULE].
[ 40.510000] Error: Driver 'gpio-keys-polled' is already registered, aborting...
[ 40.540000] PPP generic driver version 2.4.2
[ 40.690000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 41.110000] NET: Registered protocol family 24
[ 41.150000] nf_conntrack version 0.5.0 (955 buckets, 3820 max)
[ 41.900000] Linux video capture interface: v2.00
[ 42.160000] fuse init (API version 7.20)
[ 660.240000] usb 1-1.1: new high-speed USB device number 4 using ehci-platform
[ 660.370000] usb 1-1.1: New USB device found, idVendor=058f, idProduct=6366
[ 660.370000] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 660.370000] usb 1-1.1: Product: Flash Card Reader/Writer
[ 660.370000] usb 1-1.1: Manufacturer: Generic
[ 660.380000] usb 1-1.1: SerialNumber: 058F63666438
[ 660.390000] scsi1 : usb-storage 1-1.1:1.0
[ 661.390000] scsi 1:0:0:0: Direct-Access Multiple Card Reader 1.00 PQ: 0 ANSI: 0
[ 662.170000] sd 1:0:0:0: [sdb] 62324736 512-byte logical blocks: (31.9 GB/29.7 GiB)
[ 662.170000] sd 1:0:0:0: [sdb] Write Protect is off
[ 662.170000] sd 1:0:0:0: [sdb] Mode Sense: 03 00 00 00
[ 662.170000] sd 1:0:0:0: [sdb] No Caching mode page present
[ 662.180000] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 662.190000] sd 1:0:0:0: [sdb] No Caching mode page present
[ 662.190000] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 662.200000] sdb:
[ 662.210000] sd 1:0:0:0: [sdb] No Caching mode page present
[ 662.210000] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 662.210000] sd 1:0:0:0: [sdb] Attached SCSI removable disk
root@Arduino:~#
mi sembra di capire che vengono riconosciute sia la SD ( sba) che la chiavetta (sdb), ma non gli vengono assegnate le unita (sda1 ed sdb1) o no???
pictux
January 2, 2014, 9:44am
5
Ciao,
ad inserimento sd:
root@Linino:/# dmesg | grep sda
[ 11.180000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 1030.650000] sd 0:0:0:0: [sda] 3932160 512-byte logical blocks: (2.01 GB/1.87 GiB)
[ 1030.740000] sd 0:0:0:0: [sda] No Caching mode page present
[ 1030.740000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 1030.750000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 1030.830000] sda: sda1
ad inserimento USB:
root@Linino:/# dmesg | grep sdb
[ 1161.850000] sd 1:0:0:0: [sdb] 7839744 512-byte logical blocks: (4.01 GB/3.73 GiB)
[ 1161.850000] sd 1:0:0:0: [sdb] Write Protect is off
[ 1161.850000] sd 1:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 1161.850000] sd 1:0:0:0: [sdb] No Caching mode page present
[ 1161.860000] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 1161.860000] sd 1:0:0:0: [sdb] No Caching mode page present
[ 1161.870000] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 1161.870000] sdb: sdb1
[ 1161.890000] sd 1:0:0:0: [sdb] No Caching mode page present
[ 1161.890000] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 1161.890000] sd 1:0:0:0: [sdb] Attached SCSI removable disk
risultato di mount
root@Arduino:/# mount | grep sd
/dev/sda1 on /mnt/sda1 type vfat (rw,sync,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/sdb1 on /mnt/sdb1 type vfat (rw,sync,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
La sd e la chiavetta che stai usando che fs hanno?
Prova, dopo aver inserito la sd/usb, a lanciare invece di dmesg il comando:
logread | grep sd
leo72
January 2, 2014, 9:57am
6
Su Yun c'è fdisk?
Altrimenti uno può provare a vedere se "# fdisk -l" (# indica da root) ti elenca la chiavetta.
pictux
January 2, 2014, 10:48am
7
Ciao
Su Yun c'è fdisk?
di default no, ma si può installare
opkg install fdisk
in ogni caso il kernel gli vedeva il volume, ma non lo montava.
system
January 4, 2014, 10:23pm
8
Ho provo a dare il comando
logread | grep sd
e mi ha dato una serie di linee cosi:
Aug 8 22:10:22 Arduino user.info sysinit: /dev/sda: SEC_TYPE="msdos" LABEL="ARDUINOYUN" UUID="FCDF-3DEC" TYPE="vfat"
system
January 4, 2014, 10:53pm
9
Considerate che sono andato su 192.168.240.1 e da li su CONFIGURE --> advanced configuration panel quindi su System e Mount Point; li non c'era la riga
/dev/sda /mnt/sda1 1.86 GB / 1.86 GB 0% (128.00 KB)
ho dovuto aggiungere un Mount Poit con i seguenti dati :
/dev/sda (1910 MB) /mnt/sda1 vfat defaults no no
a questo punto mi è apparsa la riga
e, utilizzando WinSCp, ho visto la schedina e, utilizzando PuTTY, sono riuscito a posizionarmi sulla cartella
cd /mnt/sda1/arduino/www
e li creare un semplice file.
comunque da browser non vedo direttamente la cartella www, nel senso che se faccio 192.168.240.1/sd/hello.txt non vedo nulla ( not found); se faccio il comando ls -1l ottengo questo risultato
root@Arduino:/www# ls -1l
drwxr-xr-x 2 27 Aug 19 2013 cgi-bin
-rw-r--r-- 1 436 Jul 30 15:06 index.html
drwxr-xr-x 2 53 Aug 19 2013 keystore_manager_example
drwxr-xr-x 4 61 Aug 19 2013 luci-static
cioè mi sembra di capire che non viene creato il link simbolico
pictux
January 5, 2014, 11:25am
10
Ciao
attenzione che il contenuto della sd non viene montato in
/www
dove ci sono invece i file dell'interfaccia di amministrazione ( arduino e
luci
pictux
January 7, 2014, 2:17pm
12
Ciao,
nella folder /www ci dovrebbe essere un link simbolico sd alla folder /mnt/sda1/arduino/www
Se vuoi tamponare manualmente, creati tale link simbolico.
# ln -s /mnt/sda1/arduino/www /www/sd
system
January 7, 2014, 6:26pm
13
per fare in modo che me lo crei al boot dove devo inserire il comando ???, cioè esiste una clist che viene eseguita all'avvio ?? se si dove si trova e come si chiama ??
Grazie
pictux
January 7, 2014, 8:27pm
14
Ciao,
chiacchierando della cosa con Federico Vanzati, mi ha segnalato velocemente i file interessati.
Link qui al repository su github, così puoi confrontarli e eventualmente sostiruirli.
C'è una regola di hotplug che regola lo script la lanciare in seguito al mount (/etc/hotplug.d/block/40-mount ):
#!/bin/sh
# Copyright (C) 2009-2012 OpenWrt.org
# Copyright (C) 2010 Vertical Communications
# This is free software, licensed under the GNU General Public License v2.
# See /LICENSE for more information.
. /lib/functions/block.sh
. /lib/functions/post_mount.sh
blkdev=`dirname $DEVPATH`
if [ `basename $blkdev` != "block" ]; then
device=`basename $DEVPATH`
mountpoint=`sed -ne "s|^[^ ]*/$device ||; T; s/ .*//p" /proc/self/mounts`
case "$ACTION" in
add)
local from_fstab
This file has been truncated. show original
questo il file con lo script che viene lanciato, che crea il link simbolico in questione (/lib/functions/post_mount.sh ):
system
January 10, 2014, 5:45pm
15
Grazie adesso provo a vedere e ti faccio sapere
