Arduino Yun not serial communicate with Arduino DUE
Hi I'm trying to communicate between 2 Arduino (Yun and DUE) the sender transmit an integer and the Receiver (Arduino DUE) light on a led. If i used an Arduino UNO to send data is ok but if i Try to send from YUN i see inYUN serial monitor data but nothing arrived on the reciver. I have connected them crossing tx-rx pins (but i tried all combination)
Below the code used :
SENDER :
int val = 0;
int incoming = 0;
Serial.println("Done"); //Is not an integer so it won't interfere
if (Serial.available())
incoming = Serial.available();
Serial.print("Received value... Transmitting: ");
val = Serial.parseInt(); //Reads integers as integer rather than ASCI. Anything else returns 0
Serial.println(val); //This is being sent to the Rx board
RECEIVER :
int val = 0;
const int led = 13;
int incoming = 0;
Serial1.begin(9600);
pinMode(led, OUTPUT);
while (incoming == 0) //Keep checking until there is something available
for (int i = 0; i < val ; i++) //Flash the LED the appropriate number of times
digitalWrite(led, HIGH);
digitalWrite(led, LOW);
// Serial.println(val);
val = 0;
Any Ideas ?
Thanks
The Yun is more like a Leonardo than an UNO, so you should use Serial1 for the sending object (given you connected the Due to pins 0 and 1, by some level converters, I hope).
Thanks, i tried but nothing to do.. :frowning:
Show the wiring you used. Did you use a level converter? (Yun is 5V, DUE is 3.3V)
