Hi there im working on this code with some friends but am having trouble moving the servos correctly we have managed to parse the data correctly but the servos feel like they are trying to rotate past their extreme and are humming...
Board: Arduino YUN
Servos: Tower pro micro 9g
Any ideas gratefully recieved
Thank you
Al
#include <Servo.h>
#include <Bridge.h>
#include <HttpClient.h>
float height, pressure = 0;
String webData;
int charNumber = 0;
int combinedindex, heightindex, periodindex = 0;
float hservo, pservo ;
Servo myservo1;
Servo myservo2;
// Bridge takes about two seconds to start up
// it can be helpful to use the on-board LED
// as an indicator for when it has initialized
myservo1.attach(9);
myservo2.attach(8);
myservo1.write(0);
myservo2.write(0);
pinMode(13, OUTPUT);
digitalWrite(13, LOW);
Bridge.begin();
digitalWrite(13, HIGH);
while (!Serial); // wait for a serial connection
// Initialize the client library
HttpClient client;
// Make a HTTP request:
client.get("http://magicseaweed.com/api/6324520cb90816fa8eef8ff17dc6a44f/forecast/?spot_id=1");
//http://magicseaweed.com/api/6324520cb90816fa8eef8ff17dc6a44f/forecast/?spot_id=1
// if there are incoming bytes available
// from the server, read them and print them:
while (client.available()) {
char c = client.read();
charNumber++; //count the number of characters
if (charNumber > 200) //lets save some space
//300 put 300 for primary data
webData = webData + c;
if (charNumber > 400)//lets save some space
//500 put 300 for primary data
Serial.println(webData);
combinedindex = webData.indexOf("combined"); //search for word "combined". this part is not need because we are reading latest data from the web site
if (combinedindex > 0)
//Serial.println(combinedindex);
heightindex = webData.indexOf("height"); //search for word "height"
if (heightindex > 0)
Serial.print("Height : ");
// Serial.println(webData[heightindex+8]);
hservo = getfloat('h', heightindex); //get the float value of height
turnhservo(hservo); //turn the servo according to height value
Serial.println(hservo);
periodindex = webData.indexOf("period");
Serial.print("Period : ");
//Serial.println(periodindex);
pservo = getfloat('p', periodindex);
turnpservo(pservo);
Serial.println(pservo);
webData = ""; //set the webData string to null
charNumber = 0; //reset the number of characters counted
break; // stop the while loop
Serial.flush();
delay(5000);
float getfloat(char d, int startindex) // first argument consider if the input is for height or for period
{ //second argument is for starting index of height oor period in webData string
static int start = 0;
String val;
if ( d == 'h')
start = startindex + 8; // digits start 8 chars after the start of "height" word
for (int i = 0; i < 4; i++) //check chracters for 4 times, until it meets ","
if (webData[start + i] == ',') //if it meet "," before 4 th character, break the for loop and stop the loop
return val.toFloat(); //return the extracted value in float
val = val + webData[start + i]; //combine characters and build a new string
else if ( d == 'p')
void turnhservo(float hservo) //this is for turn the servo
if (hservo > 0.0 && hservo < 1.0 )
myservo1.write(20);
Serial.println("Servo angle : 20");
else if (hservo > 1.1 && hservo < 3.0 )
myservo1.write(40);
Serial.println("Servo angle : 40");
else if (hservo > 3.1 && hservo < 5.0 )
myservo1.write(60);
else if (hservo > 5.1 && hservo < 7.0 )
myservo1.write(80);
else if (hservo > 7.1 && hservo < 9.0 )
myservo1.write(100);
else if (hservo > 9.1 && hservo < 11.0 )
myservo1.write(120);
else if (hservo > 11.1 && hservo < 13.0 )
myservo1.write(140);
else if (hservo > 13.1 && hservo < 15.0 )
myservo1.write(160);
else if (hservo > 15.1 && hservo < 17.0 )
myservo1.write(180);
void turnpservo(float pservo)
if (pservo > 0.0 && pservo < 1.0 )
myservo2.write(20);
else if (pservo > 1.1 && pservo < 4.0 )
myservo2.write(40);
else if (pservo > 4.1 && pservo < 6.0 )
myservo2.write(60);
Serial.println("Servo angle : 60");
else if (pservo > 6.1 && pservo < 8.0 )
myservo2.write(80);
else if (pservo > 8.1 && pservo < 10.0 )
myservo2.write(100);
else if (pservo > 10.1 && pservo < 12.0 )
myservo2.write(120);
else if (pservo > 12.1 && pservo < 13.0 )
myservo2.write(140);
else if (pservo > 13.1 && pservo < 15.0 )
myservo2.write(160);
else if (pservo > 15.1 && pservo < 25.0 )
myservo2.write(180);
