Arduino Yun Rev 2 - using serial output. Serial Plotter, Graph etc.
I can read data from analogue pins and display in Serial monitor, log data from a sensor to an SD card. It is file.txt.
Btw. What is the easiest and quickest way to display data on the graph, I would like to use something like Serial Plotter but if I am using a WiFi Port I can't use it.
How to do this?
I just found this link
Is it true that we have to use an external application to display data?
Anybody?
If serial monitor can show the data, serial plotter should also be able to show the data.
Can't help you further (not a yun user) but you should not need an additional application.
