Arduino Yún, SNMP, and Sensor Data Question
Hello,
I'm considering an Arduino Yún, but I'm not finding some specific information for my use case.
Is it possible to take sensor input, say for a weather station (temperature, humidity, wind speed, etc..) and pass the values to the Yún side Linux instance such that an SNMP daemon under OpenWRT can present the data as OID values?
I'd like to be able to query each sensor input as an SNMP OID such than an external system can trend graph the data. I'm not interested in using the Temboo service if it can be avoided.
Thank you,
I read that 3 times and my brain is still spinning. I have no clue what you just said but I am sure you do. I'll monitor this post to see if I can learn something .
Hello Brandon,
To my opinion this can be done with the Yun. The sensor input can be shared via the bridge. And you can use python (PySMP) for the OID values.
Best regards,
python-yapsnmp_0.7.8-1_ar71xx.ipk is available as a package.
please read http://yapsnmp.sourceforge.net/ for more information.
For the record, a list of available packages is available here
http://downloads.arduino.cc/openwrtyun/1/packages/index.html
Excellent. I've never worked with Python, but I suppose this gives me a good excuse to learn something new.
Thank you,
it seems that yapsnmp does not support the agent functionality that you are looking for. Pysnmp should do the trick, but is not available as a Yun package. I'm in the process of installing it. If it works I let you know.
I've got the snmp side working on the yun. I've managed to install pysnmp en can now perform a get on a python snmp agent. Now the next step is to merge below code with the Yun bridge and you have a working solution. Good luck.
To install pysnmp, please follow the steps on http://tavendo.com/blog/post/arduino-yun-with-autobahn/ untill the "twisted" part. And then download and install pysnmp.
For these instructions you need a SD card for the Yun.
Then you can run the following code:
Agent python code:
from pysnmp.carrier.asynsock.dispatch import AsynsockDispatcher
from pysnmp.carrier.asynsock.dgram import udp, udp6
from pyasn1.codec.ber import encoder, decoder
from pysnmp.proto import api
import time, bisect
class SysDescr:
    name = (1,3,6,1,2,1,1,1,0)
    def __eq__(self, other): return self.name == other
    def __ne__(self, other): return self.name != other
    def __lt__(self, other): return self.name < other
    def __le__(self, other): return self.name <= other
    def __gt__(self, other): return self.name > other
    def __ge__(self, other): return self.name >= other
    def __call__(self, protoVer):
        return api.protoModules[protoVer].OctetString(
            'Yun PySNMP example command responder'
class Uptime:
    name = (1,3,6,1,2,1,1,3,0)
    birthday = time.time()
        return api.protoModules[protoVer].TimeTicks(
            (time.time()-self.birthday)*100
mibInstr = (
    SysDescr(), Uptime() # sorted by object name
mibInstrIdx = {}
for mibVar in mibInstr:
    mibInstrIdx[mibVar.name] = mibVar
def cbFun(transportDispatcher, transportDomain, transportAddress, wholeMsg):
    while wholeMsg:
        msgVer = api.decodeMessageVersion(wholeMsg)
        if msgVer in api.protoModules:
            pMod = api.protoModules[msgVer]
        else:
            print('Unsupported SNMP version %s' % msgVer)
            return
        reqMsg, wholeMsg = decoder.decode(
            wholeMsg, asn1Spec=pMod.Message(),
        rspMsg = pMod.apiMessage.getResponse(reqMsg)
        rspPDU = pMod.apiMessage.getPDU(rspMsg)
        reqPDU = pMod.apiMessage.getPDU(reqMsg)
        varBinds = []; pendingErrors = []
        errorIndex = 0
        # GETNEXT PDU
        if reqPDU.isSameTypeWith(pMod.GetNextRequestPDU()):
            # Produce response var-binds
            for oid, val in pMod.apiPDU.getVarBinds(reqPDU):
                errorIndex = errorIndex + 1
                # Search next OID to report
                nextIdx = bisect.bisect(mibInstr, oid)
                if nextIdx == len(mibInstr):
                    # Out of MIB
                    varBinds.append((oid, val))
                    pendingErrors.append(
                        (pMod.apiPDU.setEndOfMibError, errorIndex)
                else:
                    # Report value if OID is found
                    varBinds.append(
                        (mibInstr[nextIdx].name, mibInstr[nextIdx](msgVer))
        elif reqPDU.isSameTypeWith(pMod.GetRequestPDU()):
                if oid in mibInstrIdx:
                    varBinds.append((oid, mibInstrIdx[oid](msgVer)))
                else:
                    # No such instance
                        (pMod.apiPDU.setNoSuchInstanceError, errorIndex)
                    break
        else:
            # Report unsupported request type
            pMod.apiPDU.setErrorStatus(rspPDU, 'genErr')
        pMod.apiPDU.setVarBinds(rspPDU, varBinds)
        # Commit possible error indices to response PDU
        for f, i in pendingErrors:
            f(rspPDU, i)
        transportDispatcher.sendMessage(
            encoder.encode(rspMsg), transportDomain, transportAddress
    return wholeMsg
transportDispatcher = AsynsockDispatcher()
transportDispatcher.registerRecvCbFun(cbFun)
# UDP/IPv4
transportDispatcher.registerTransport(
    udp.domainName, udp.UdpSocketTransport().openServerMode(('localhost', 161))
transportDispatcher.jobStarted(1)
try:
    # Dispatcher will never finish as job#1 never reaches zero
    transportDispatcher.runDispatcher()
except:
    transportDispatcher.closeDispatcher()
    raise
SNMP get code:
from time import time
# Protocol version to use
pMod = api.protoModules[api.protoVersion1]
#pMod = api.protoModules[api.protoVersion2c]
# Build PDU
reqPDU =  pMod.GetRequestPDU()
pMod.apiPDU.setDefaults(reqPDU)
    reqPDU, ( ('1.3.6.1.2.1.1.1.0', pMod.Null('')),
              ('1.3.6.1.2.1.1.3.0', pMod.Null('')) )
# Build message
reqMsg = pMod.Message()
pMod.apiMessage.setDefaults(reqMsg)
pMod.apiMessage.setCommunity(reqMsg, 'public')
pMod.apiMessage.setPDU(reqMsg, reqPDU)
startedAt = time()
def cbTimerFun(timeNow):
    if timeNow - startedAt > 3:
        raise Exception("Request timed out")
def cbRecvFun(transportDispatcher, transportDomain, transportAddress,
              wholeMsg, reqPDU=reqPDU):
    while wholeMsg:
        rspMsg, wholeMsg = decoder.decode(wholeMsg, asn1Spec=pMod.Message())
        # Match response to request
        if pMod.apiPDU.getRequestID(reqPDU)==pMod.apiPDU.getRequestID(rspPDU):
            # Check for SNMP errors reported
            errorStatus = pMod.apiPDU.getErrorStatus(rspPDU)
            if errorStatus:
                print(errorStatus.prettyPrint())
            else:
                for oid, val in pMod.apiPDU.getVarBinds(rspPDU):
                    print('%s = %s' % (oid.prettyPrint(), val.prettyPrint()))
            transportDispatcher.jobFinished(1)
    return wholeMsg
transportDispatcher.registerRecvCbFun(cbRecvFun)
transportDispatcher.registerTimerCbFun(cbTimerFun)
# UDP/IPv4
    udp.domainName, udp.UdpSocketTransport().openClientMode()
# Pass message to dispatcher
    encoder.encode(reqMsg), udp.domainName, ('127.0.0.1', 161)
# Dispatcher will finish as job#1 counter reaches zero
Feedback, you rock! Thank you.
I'm not yet sure exactly what you've laid out for me there, but I'll do my best to implement and understand it. My Yún is on its way, so I can begin tinkering in the near future. I'm sure I'll be back with more questions.
Cheers!
Hello Brandon,
Victory! I've managed to read the tempature via the Atmel ATMega32U4 side. Push this info to a file. Then on the linino side running an SNMp agent with python reading the file and responding to a SNMP request from Cacti. Cacti is now monitoring the tempature in my room! :slight_smile:
Please note that this is a fast proof of concept and the code is not so nice... Also I would have used the serial connection between the 32U4 and Linino. But my experience with python is only from this project. For now I used the SD logger function and read the information from a file.
Notes:
  • TMP36 is used
  • oid = .1.3.6.1.2.1.1.1.0
  • In the python script, please use your IP address of the Yun and replace the x.x.x.x in the python code.
32U4 code:
  SNMP tempature proof of concept via SNMP/Cacti
 SD card datalogger
 This example shows how to log data from three analog sensors
 to an SD card mounted on the Arduino Yún using the Bridge library.
 The circuit:
 * analog sensors on analog pins 0, 1 and 2
 * SD card attached to SD card slot of the Arduino Yún
 Prepare your SD card creating an empty folder in the SD root
 named "arduino". This will ensure that the Yún will create a link
 to the SD to the "/mnt/sd" path.
 You can remove the SD card while the Linux and the
 sketch are running but be careful not to remove it while
 the system is writing to it.
 created  24 Nov 2010
 modified 9 Apr 2012
 by Tom Igoe
 adapted to the Yún Bridge library 20 Jun 2013
 by Federico Vanzati
 modified  21 Jun 2013
 by Tom Igoe
 This example code is in the public domain.
//TMP36 Pin Variables
int sensorPin = 0; //the analog pin the TMP36's Vout (sense) pin is connected to
                        //the resolution is 10 mV / degree centigrade with a
                        //500 mV offset to allow for negative temperatures
#include <FileIO.h>
  // Initialize the Bridge and the Serial
  Bridge.begin();
  FileSystem.begin();
  //while(!Serial);  // wait for Serial port to connect.
  //Serial.println("Filesystem datalogger\n");
void loop () {
  // make a string that start with a timestamp for assembling the data to log:
  String dataString;
  dataString += "Integer: ";
  //dataString += getTimeStamp();
  //dataString += " = ";
 //getting the voltage reading from the temperature sensor
 int reading = analogRead(sensorPin);
 // converting that reading to voltage, for 3.3v arduino use 3.3
 float voltage = reading * 4.5;
 voltage /= 1024.0;
 // print out the voltage
 //Serial.print(voltage); Serial.println(" volts");
 // now print out the temperature
 float temperatureC = (voltage - 0.5) * 100 ;  //converting from 10 mv per degree wit 500 mV offset
                                               //to degrees ((voltage - 500mV) times 100)
 //Serial.print(temperatureC); Serial.println(" degrees C");
 dataString += String(temperatureC);
  // open the file. note that only one file can be open at a time,
  // so you have to close this one before opening another.
  // The FileSystem card is mounted at the following "/mnt/FileSystema1"
  File dataFile = FileSystem.open("/mnt/sd/datalog.txt", FILE_APPEND);
  // if the file is available, write to it:
  if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    //Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    //Serial.println("error opening datalog.txt");
  delay(60000);
// This function return a string with the time stamp
String getTimeStamp() {
  String result;
  Process time;
  // date is a command line utility to get the date and the time
  // in different formats depending on the additional parameter
  time.begin("date");
  time.addParameter("+%D-%T");  // parameters: D for the complete date mm/dd/yy
                                //             T for the time hh:mm:ss
  time.run();  // run the command
  // read the output of the command
  while(time.available()>0) {
    char c = time.read();
    if(c != '\n')
      result += c;
  return result;
Python agent code:
import time, bisect
import subprocess
class SysDescr:
        #data = 'Hallo'
        proc = subprocess.Popen(['tail', '-1', '/mnt/sd/datalog.txt'], stdout=subprocess.PIPE)
        for line in proc.stdout.readlines():
            data = line.rstrip()
            data
class Uptime:
mibInstr = (
mibInstrIdx = {}
    while wholeMsg:
        else:
            return
        errorIndex = 0
        # GETNEXT PDU
                    # Out of MIB
                else:
                    varBinds.append(
                else:
                    # No such instance
                    break
        else:
            f(rspPDU, i)
    return wholeMsg
# UDP/IPv4
    udp.domainName, udp.UdpSocketTransport().openServerMode(('x.x.x.x', 161))
try:
except:
    raise
To check that the snmp agent is working, you can use the following Python script:
# Build PDU
# Build message
startedAt = time()
    while wholeMsg:
            if errorStatus:
            else:
    return wholeMsg
# UDP/IPv4
    encoder.encode(reqMsg), udp.domainName, ('x.x.x.x', 161)
Enjoy!
May i refresh this Thread?
I was able to follow until the point where "Feedback" is pointing to:
Agent python code: (code in the box)
in the post from 4. Aug. and 4 Posts above.
Whats the difference between the Agent Phyton Code and the SNMP Get code?
Does it have to be loaded to a separated storage (i now i have 2 on my SDcard...) or is it a new part in the Sketch?
Thanks for help.
novski
novski:
::::SNIP::::
No, please start a NEW TOPIC on the main webpage.
Jesse
http://forum.arduino.cc/index.php?topic=306583
