Arduino Yun: Storing Data in Mysql installed on Linino
i want to store data from a temperature sensor connected in A0 pin.
In linino side with mysql-server, i created a sql database called 'ARDUINO' which contains a table, called 'temperatura' with 3 columns: 'id', 'data' and 'tempdegree'.
How can Arduino fill this table with the sensor Data Output?
Anybody can help me?
Best Regards,
nlourenco
  1. Install mySQL server:
http://wiki.openwrt.org/doc/howto/lamp
  1. Setup python-mysql
http://forum.arduino.cc/index.php?topic=206746.msg1524868#msg1524868
mysql> CREATE DATABASE ARDUINO;
mysql> USE ARDUINO;
mysql> CREATE TABLE temperatura (id INT, data VARCHAR(20), tempdegree VARCHAR(20));
mysql> SHOW TABLES;
opkg update
opkg install python-mysql
nano /mnt/sda1/mysql.py
#!/usr/bin/python
# -*- coding: utf-8 -*-
import _mysql
import sys, string, os
#print sys.argv
try:
      con = _mysql.connect('127.0.0.1', 'root', 'new-password', 'ARDUINO')
      #con.query("SELECT VERSION()")
      #result = con.use_result()
      #print "MySQL version: %s" %  result.fetch_row()[0]
    sqlstr="INSERT INTO temperatura (id,data ,tempdegree) VALUES( " + sys.argv[1] +", '" + sys.argv[2] + "', '" + sys.argv[3] + "')"
    #print  sqlstr
    con.query(sqlstr)
except _mysql.Error, e:
      print "Error %d: %s" % (e.args[0], e.args[1])
      sys.exit(1)
finally:
      if con:
                con.close()
chmod 755  /mnt/sda1/mysql.py
/mnt/sda1/mysql.py  2  'test1' 'test2'
confirm data insert into table.
  1. ATmega32u4 side.
http://arduino.cc/en/Tutorial/Process
void insertdb() {
  Process p;
  p.begin("/mnt/sda1/mysql.py");
  p.addParameter("1");
  p.addParameter("32");
  p.addParameter("64");
  p.run();
Thanks :D
I will try
Revision 2:
Setup timezone and NTP ( RTC) at LUCI
Create table with AUTO_INCREMENT and TIMESTAMP.
CREATE TABLE temperatura_new (
id INT NOT NULL AUTO_INCREMENT,
tempdegree VARCHAR(20),
insert_date TIMESTAMP,
PRIMARY KEY (id)
Insert test data.
INSERT INTO temperatura_new (tempdegree) VALUES ( '32');
INSERT INTO temperatura_new (tempdegree) VALUES ( '34');
select * from temperatura_new;
| id | tempdegree | insert_date         |
|  1 | 32         | 2014-02-03 10:08:51 |
|  2 | 34         | 2014-02-03 10:08:57 |
The python script now only need pass one parameter only.
Thanks :D So the pyhton code, comes like this: sqlstr="INSERT INTO temperatura (tempdegree) VALUES( " + sys.argv[1] +")" ???
I have some doubts in the arduino code, to get the data from sensor A0:
int sensorValue = analogRead(A0);
void insertdb() {
  Process p;
  p.addParameter("sensorValue");
  p.run();
it returns me an error.
Best Regards
sqlstr="INSERT INTO temperatura (tempdegree) VALUES( '" + sys.argv[1] +"')"
Run
/mnt/sda1/mysql.py    '32'
at console to confirm data insert into table .
Please post error message.
I’ve tried to do what you have said.
What i do:
  • I created the file mysql.py, and i copy to the mini sd root, in the path /mnt/sda1/mysql.py
  • My file mysql.py, looks like this:#!/usr/bin/python
-- coding: utf-8 --
import _mysql
#print sys.argv
try:
con = _mysql.connect(‘192.168.0.104’, ‘root’, ‘mypassword’, ‘homeautomation’)
#con.query(“SELECT VERSION()”)
#print “MySQL version: %s” % result.fetch_row()[0]
sqlstr=“INSERT INTO NossoTeste (valor ,tensao) VALUES( " + sys.argv[1] +”, ‘" + sys.argv[2] + "’)"
#print sqlstr
con.query(sqlstr)
print “Error %d: %s” % (e.args[0], e.args[1])
sys.exit(1)
finally:
if con:
con.close()
  • When i try to run it, in the linino console, with the command: /usr/bin/python /mnt/sda1/mysql.py , it returns me an error :" Error 2002: Can’t connect to local MySQL server through socket ‘/tmp’ (146)
    Traceback (most recent call last):
    File “/mnt/sda1/mysql.py”, line 25, in
    if con:
    NameError: name ‘con’ is not defined
Can you help me please?
My bind adress, in the mysql server is defined by arduino IP in my lan, in this case 192.168.0.104.
I have to do that, to link the toad software installed on my PC, to the database installed on linino side.
Thanks,
use "127.0.0.1"
You mean, use 127.0.0.1 in bind-adress??
I can't do that.
If i put 127.0.0.1 in bind-adress, i will no longer available, to connect my db software installed on my PC, to the db stored in Arduino.
I think, if i put 0.0.0.0, MySQL will listen all available interfaces.
Tks
Python code:
try:
At my.conf if bind-address = 0.0.0.0 is not working,
# bind-address = 127.0.0.1  # comment this line out
mysqld will be listening on 0.0.0.0:3306.
mysql> GRANT ALL PRIVILEGES ON *.* TO root@'%' IDENTIFIED BY 'new-password';
grant right to root@anyipaddress.
Tks, i put 0.0.0.0 in bind adress, and now i can write values on my db table, stored in Linino through an IDE installed on my PC.
So I pick your code anda i made some changes:
try:
      con = _mysql.connect('192.168.0.100', 'NSL', 'teste', 'homeautomation')
    sqlstr="INSERT INTO NossoTeste (valor,tensao) VALUES(1,7)"
    #print  sqlstr
    con.query(sqlstr)
The Values 1 and 7 were inserted on my 'Nosso Teste' Table.
Then i've tried to do something different:
valio= 5
tension= 4.88
try:
    sqlstr=("INSERT INTO NossoTeste (valor,tensao) VALUES(%s,%s)",(valio,tension))
    #print  sqlstr
    con.query(sqlstr)
And it returns me an error: TypeError: must be string or read-only buffer, not tuple
Do you know how to solve it? Sorry i'm a newbie at python!
Tks
mysql -uroot -p
get mysql console:
use homeautomation;
show create table NossoTeste;
post the result here.
at python code:
print  sqlstr
#con.query(sqlstr)
mysql result:
mysql> show create table NossoTeste;
| Table      | Create Table        |
| NossoTeste | CREATE TABLE `NossoTeste` (
  `id` int(2) NOT NULL AUTO_INCREMENT,
  `valor` int(11) DEFAULT NULL,
  `tensao` decimal(3,2) DEFAULT NULL,
  PRIMARY KEY (`id`)
) ENGINE=MyISAM AUTO_INCREMENT=17 DEFAULT CHARSET=latin1 |
1 row in set (0.00 sec)
Python Code:
#!/usr/bin/python
import _mysql
#print sys.argv
valio= 5
tension= 4.88
try:
    print  sqlstr
#   con.query(sqlstr)
      sys.exit(1)
finally:
      if con:
                con.close()
Python Result:
Python 2.7.6 (default, Nov 10 2013, 19:24:18) [MSC v.1500 32 bit (Intel)] on win32
Type "help", "copyright", "credits" or "license" for more information.
Imported NumPy 1.8.0, SciPy 0.13.3, Matplotlib 1.3.1
+ guidata 1.6.1, guiqwt 2.3.1
Type "scientific" for more details.
>>> runfile('C:/Users/Nuno/.spyder2/mysql.py', wdir=r'C:/Users/Nuno/.spyder2')
('INSERT INTO NossoTeste (valor,tensao) VALUES(%s,%s)', (5, 4.88))
I do this:
root@Arduino:~# /usr/bin/python /mnt/sda1/mysql.py 1000 2
:slight_smile: and it was inserted in my db, the values 1000 and 2, id nº 17:
mysql> SELECT * from NossoTeste;
| id | valor | tensao |
|  1 |     1 |   NULL |
|  2 |     0 |   0.00 |
|  3 |     0 |   0.00 |
|  4 |     0 |   0.00 |
|  5 |     2 |   4.00 |
|  6 |  NULL |   NULL |
|  7 |  NULL |   NULL |
|  8 |     6 |   4.00 |
|  9 |     0 |   0.00 |
| 10 |     0 |   0.00 |
| 11 |     0 |   0.00 |
| 12 |     0 |   0.00 |
| 13 |     5 |   6.00 |
| 14 |     1 |   4.00 |
| 15 |     4 |   8.00 |
| 16 |     1 |   7.00 |
| 17 |  1000 |   2.00 |
| 18 |  1024 |   4.88 |
18 rows in set (0.00 sec)
Then In arduino code, i put this:
#include <Process.h>
Bridge.begin();
void insertdb() {
  Process p;
  p.begin("/usr/bin/python /mnt/sda1/mysql.py");
  p.run();
But it didn’t work, values 1 and 64 weren’t inserted in my db.
What i’m doing wrong?
I found the solution ehehe
Bridge.begin();
insertdb();
void insertdb() {
  Process p;
  p.begin("/usr/bin/python");
  p.addParameter("/mnt/sda1/mysql.py");
  p.addParameter("10");
  p.addParameter("2.27");
  p.run();
Now it works :smiley:
You are missing "#!/usr/bin/python" at beginning of python.
That's strange... because i've already that line in my code:
#!/usr/bin/python
import _mysql
#print sys.argv
try:
      con = _mysql.connect('127.0.0.1', 'root', '123456789', 'homeautomation')
    sqlstr="INSERT INTO NossoTeste (valor ,tensao) VALUES( " + sys.argv[1] +", '" + sys.argv[2] + "')"
    #print  sqlstr
    con.query(sqlstr)
      sys.exit(1)
finally:
      if con:
                con.close()
If i put, in the command line just: /mnt/sda1/mysql.py -ash: /mnt/sda1/mysql.py: not found
One more problem:
if i put values in addparameter, this work perfectly.
Ex:
Bridge.begin();
insertdb();
void insertdb() {
  Process p;
  p.run();
But if i put values from a variable, it returns an error.
Ex:
int sensorPin = 0;
int teste1 = 1005;
int teste2= 4.23;
Serial.println("Bit \t Tensao (V)");
Bridge.begin();
 insertdb(teste1, teste2);
int reading = analogRead(sensorPin);
float tensao = reading * 4.88;
 tensao /= 1024.0;
Serial.print(reading);
 Serial.print("\t");
 Serial.print("\t");
 Serial.print(tensao);
 Serial.print("\t");
 Serial.print("\n");
void insertdb(int x, int y) {
  Process p;
  p.addParameter(x);
  p.addParameter(y);
  p.run();
the error is:
Arduino: 1.5.6-r2 (Windows 8), Placa:“Arduino Yún”
ler_tensoes.ino: In function ‘void insertdb(int, int)’:
ler_tensoes:32: error: conversion from ‘int’ to ‘const String’ is ambiguous
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/WString.h:61: note: candidates are: String::String(const __FlashStringHelper*)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/WString.h:59: note: String::String(const char*)
ler_tensoes:33: error: conversion from ‘int’ to ‘const String’ is ambiguous
Best Regards
String stringOne =  String(analogRead(0), DEC);     // using an int and a base
String stringOne =  String(13);                     // using a constant integer
void insertdb(String x, String y) {
http://arduino.cc/en/Tutorial/StringConstructors#.UxwMAvldVtU
Thanks :D it worked
