Arduino YUN strange behaviour
Hi everyone, i'm programming a YUN to make a data logger. It worked for a couple of days, never perfectly but worked. Then it stopped working and i'm trying to understand adding some debug lines where the problem is. I detected it is somewhere in this piece of code (which worked in other sketches i used on the same board) which suddenly stopped working from one day to another.
WriteSysLog("Updating system datetime...");
  String result;
  Process time;
  // date is a command line utility to get the date and the time
  // in different formats depending on the additional parameter
  time.begin("date");
  time.addParameter("+%D");  // parameters: D for the complete date mm/dd/yy
        //01234567
  WriteSysLog("starting date process...");
  time.run();  // run the command
  WriteSysLog("Process ended");
  // read the output of the command
  while(time.available()>0) {
    char c = time.read();
    WriteSysLog(String(c));
    if(c != '\n')
      result += c;
The result in the Serial monitor is the following. Please note the long delays between serial outputs, which usually take milliseconds:
about 30 seconds
about 23 seconds
Process ended
and then the time.read() function starts giving those results without any sense every 10 secs
ƒ
E
i do not understand what happened to my YUN, can somebody help me pls? :'(
Why round trip?
Utilize database TIMESTAMP is far more efficient than application layer.
Storing Data in Mysql/SQLITE3 with TIMESTAMP:
http://forum.arduino.cc/index.php?topic=318295.msg2202176#msg2202176
If you do file system log, you still could use Openwrt (Linux) application layer to TIMESTAMP.
Sounds cool and of course more clean. I'll give it a try. I haven't used a database before because I thought it could take more resources than file system and it could make the arduino more instable than now.
niddu: ::::SNIP::::
@niddu,
Where is the rest of your code? This makes no sense.
Jesse
jessemonroy650: @niddu,
Jesse
The test of the code is working fine and I detected the critic part was in the section of code I posted. The full sketch was about 400 lines of code.
@sonnyyu You were right, I'm trying to follow your suggestions and it seems it is working much better now!
sonnyyu: Why round trip?
It works great!! now i can make a lot of reports/query to display data on PHP. Thanks!
I've got a question, how do you pass a string with spaces and maybe special chars in it as a parameter from the arduino sketch to a PHP?
EG:
void WriteLog(String text)
 Process p;
 p.begin("/mnt/sda1/insertLog.php");
 p.addParameter(String(text));
 p.run();
where text = "some log from my sketch!!!"
niddu: where text = "some log from my sketch!!!"
I'm not at my Yun and can't try it, but my first thought is to enclose the string in double quotes:
text = "\"some log from my sketch!!!\""
To put a double quote inside a double quoted string, you need to prefix it with a backslash escape character.
