I read from the Arduino Yun webpage the following:
It is recommended to power the board via the micro-USB connection with 5VDC.
So what are, in your opinion, the risks of using the Vin pin instead of the micro-USB? It is because of the lack of the 5V regulator, so you have to be sure to provide exact 5V? or there is something else?
Thanks,
elle
system
March 15, 2014, 8:56pm
2
The timing of your question couldn't have been better. I've recently been experimenting with solar powering my yun ([SOLVED]Yun + Solar w/12v Battery - Arduino Yún - Arduino Forum ).
You are absolutely correct about the lack of regulator. Since there isn't one for the Vin, I use a traco power 1-2450 like these: http://www.newark.com/tracopower/tsr-1-2450/dc-dc-conv-non-iso-pol-1-o-p-1a/dp/08R5932?CMP=KNC-GPLA . I'm also experimenting with these at the moment though they are less efficient:http://www.amazon.com/Fairchild-Semiconductor-LM7805CT/dp/B00AZVJB54/ref=sr_1_1?ie=UTF8&qid=1394917228&sr=8-1&keywords=7805ct+Transistor .
Basically, it depends on your power requirements, environment, etc. Other than providing unregulated voltage, I don't see any problems with using external power. I personally enjoy having the freedom of choosing ;).
Thank you Duke for the suggestion, I appreciate!
elle
