Hello guys my name is Linda, from Italy! I have just started using Arduino Yun and i'm trying to print the values of the temperature sensor (LM35) and the humidity sensor (HIH4000) into two HTML textboxes and if the temperature or humidity is too high, we click an HTML button which activate two motor( that stabilize values.
I need the arduino sketch and the relative html program. Thank you so much for your help! bye bye <3
Could you please go back and choose "modify" (under "more" below and to the right of the submission) to correct the problem with your subject line where you had the Caps Lock key on?
Show us the code you have so far.
Guys I'm creating a web page where I turn on a fan through the yun and I display the values of temperature and humidity always on the page. The html code worked fine, but when I decided to connect a LCD display to render them the values of temperature and humidity, the web page from 0 to both temperature and humidity and the fan remains off button. This is a piece of code:
#include <Bridge.h>
#include <YunServer.h>
#include <YunClient.h>
#include <LiquidCrystal.h>
LiquidCrystal LCD (12,11,5,4,3,2);
int DigitalPin = 8;
YunServer server;
void setup () {
pinMode (8, OUTPUT);
Bridge.begin ();
server.listenOnLocalhost ();
server.begin ();
lcd.begin (16.2);
void loop ()
YunClient client server.accept = ();
if (client)
process (client);
client.stop ();
delay (50);
int tmp = analogRead (A0);
int t = map (tmp, 0,1023,0,100);
Serial.println (t);
String s1 = "temperature =";
String temperature = s1 + t;
lcd.setCursor (0,0);
lcd.print (temperature);
lcd.setCursor (14.0);
lcd.print ((char) (223));
delay (2000);
int = umd analogRead (A1);
int u = map (umd, 0,1023,0,100);
Serial.println (u);
String s2 = "Humidity =";
String p = "%";
String s2 + moisture = u + p;
lcd.setCursor (1.0);
lcd.print (moisture);
delay (2000);
The problem is in the loop void, if anyone knows do you work simultaneously on both the web page on 'lcd her help would be really valuable.
