Arduino Yun weird network problem
Hi hope someone can help with Yun network problem. I have 2 identical Yun's except for name and IP address, using their wifi interface to connect to a router/hotspot. Each is in a separate physical location on separate network. On one of them I cannot connect to it over the local network, for example, I cannot even get to its URL - I get a timeout. However if I open port 80 on my router and access it remotely it works! The other Yun is fine on its local LAN. Any help appreciated.
Probably the difference is the WiFi router you use in the network. One of them is isolating the devices the other isn't.
