Arduino Yun Wifi Hotspot with Ralink RT5370
I've just bought a wifi dongle with Ralink RT5370 Chipset.
The installation of the related packages was fine and Linino recognized the new dongle.
opkg install kmod-rt2800-lib kmod-rt2800-usb kmod-rt2x00-lib kmod-rt2x00-usb
I tried to disable the internal WIFI and enable the new one via Luci Interface and modifying /etc/config/wireless but I didn't solved the problem. My pc tries to connect to the wifi (new dongle interface) but gets no IP. I think it's Linino's DHCP server problem . Have you got some tips? Thanks
rockeronline00:
::::SNIP::::
@rockeronline00,
Yes. Why are you turning off a perfectly good wifi?
Jesse
Because I'm building an Arduino Yun-based quadcopter and Arduino's Wifi sucks... only 5 meters -.-
rockeronline00:
@rockeronline00,
then add an antenna and turn up the power.
Google arudino yun attenna
Connecting external antenna to Arduino Yun
OpenWrt Wireless FAQ
http://wiki.openwrt.org/doc/faq/faq.wireless
Jesse
Hi Jesse,
thanks but I have already read those posts on external antenna, and as you could see, there's no possibility.
So as I posted above, I'm trying with a dongle Wifi since OpenWrt recognizes it.
My problems come from OpenWrt's DHCP server.. When I enable the dongle (and disable the internal antenna) DHCP doesn't work anymore .
So my PC finds the new network (of the new dongle wifi) but can't connect due to this problem
Do it at your own risk! ( back up your own data)
/usr/bin/reset-to-factory-anyway
opkg update
cd /etc/modules.d
mv 24-rt2x00-lib 22-rt2x00-lib
mv 26-rt2x00-usb 23-rt2x00-usb
mv 27-rt2800-lib 24-rt2800-lib
mv 28-rt2800-usb 25-rt2800-usb
reboot Yun
mv /etc/config/wireless /var
wifi detect > /etc/config/wireless
nano /etc/config/wireless
config wifi-device  radio1
option disabled 0
reboot Yun then test
Tenda W311MI (Ralink RT5370 base USB Adapter)
http://www.amazon.com/Tenda-W311M-150Mbps-Wireless-Adapter/dp/B006GCYAOS
$13.61 2 days free shipping
Wow it works !!! You can't imagine how I'm happy !!! thank you so much !!
it does not seem to work anymore. The arduino freezes as soon as the wifi dongle is enabled. Did anyone managed to make it work?
reboot
is very important. and follow rest step carefully.
Disable internal radio might help.
config wifi-device  radio0
option disabled 1
clynamen:
@clynamen,
the person with original post did. And several other people also.
Make sure to follow SonnyYu’s instructions. Make sure the dongle is on tightly. A loose dongle will cause a weak electrical link and the software will stall and freeze.
Jesse
I actually didn't realize the post was so recent, and I though that an update caused a break. Thanks for your information, I'll retry again
rockeronline00:
thanks but I have already read those posts on external antenna, and as you could see, there’s no possibility.
Actually, although a little kludgey, a low cost solution has been found: http://forum.arduino.cc/index.php?topic=188976.msg2214560#msg2214560
