Arduino Yun WiFi Lan
Hallo
ich habe mir ein Arduino Yun zugelegt.
Leifer funktionieren die Beispielprojekte für WiFi nicht.
Wie wird bei einem Yun eine Ehernt client oder Wifi Client eingerichtet.
Habe ein Projekt für ein Arduino Uno
Kann mir jemand helfen wie ich dies auf Yun Lan und Wifi ändern muss ?
 RUN/STOP Demo
 Created 19 Nov 2013
 by Davide Nardella
                            WARNING
        This demo will perform cyclic RUN/STOP to your CPU
            Don't use it in a production Environment
                    Use it at your own risk
The model extended is needed.
- During the loop, try to disconnect the ethernet cable.
  The system will report the error and will reconnect automatically
  when you re-plug the cable.
- This demo uses ConnectTo() with Rack=0 and Slot=2 (S7300)
  - If you want to connect to S71200/S71500 change them to Rack=0, Slot=0.
  - If you want to connect to S7400 see your hardware configuration.
  - If you want to work with a LOGO 0BA7 or S7200 please refer to the
    documentation and change
    Client.ConnectTo(<IP>, <Rack>, <Slot>);
    with the couple
    Client.SetConnectionParams(<IP>, <LocalTSAP>, <Remote TSAP>);
    Client.Connect();
#include <SPI.h>
#include <Ethernet.h>
#include "Settimino.h"
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x0F, 0x08, 0xE11 };
IPAddress Local(192,168,0,70); // Local Address
IPAddress PLC(192,168,0,71);   // PLC Address
S7Client Client;
// Setup : Init Ethernet and Serial port
     while (!Serial) {
      ; // wait for serial port to connect. Needed for Leonardo only
    // Start the Ethernet Library
    Ethernet.begin(mac, Local);
    // Setup Time, someone said me to leave 2000 because some
    // rubbish compatible boards are a bit deaf.
    delay(2000);
    Serial.println(Ethernet.localIP());
// Connects to the PLC
bool Connect()
    int Result=Client.ConnectTo(PLC,
                                  0,  // Rack (see the doc.)
                                  2); // Slot (see the doc.)
    Serial.print("Connecting to ");Serial.println(PLC);
    if (Result==0)
      Serial.print("Connected ! PDU Length = ");Serial.println(Client.GetPDULength());
      Serial.println("Connection error");
    return Result==0;
// Prints the Error number
void CheckError(int ErrNo)
  Serial.print("Error No. 0x");
  Serial.println(ErrNo, HEX);
  // Checks if it's a Severe Error => we need to disconnect
  if (ErrNo & 0x00FF)
    Serial.println("SEVERE ERROR, disconnecting.");
    Client.Disconnect();
// Main Loop
  int Result, Status;
  // Connection
  while (!Client.Connected)
    if (!Connect())
  Result = Client.GetPlcStatus(&Status);
  if (Result==0)
    if (Status==S7CpuStatusRun)
      Serial.println("STOPPING THE CPU");
      Client.PlcStop();
      Serial.println("STARTING THE CPU");
      Client.PlcStart();
    CheckError(Result);
  delay(3000);
Hast Du versucht die Frage auf englisch in der Englischen Yun Bereich des Forums zu stellen? http://forum.arduino.cc/index.php?board=93.0
Der yun ist wenig Verbreitet und darum haben wenige damit Erfahrung.
Grüße Uwe
Nein noch nicht.
Ich hoffe ja das sich das Yun in DE durchsetzt.
