Arduino Yun WifiStatus Example Failing
I am able to connect and upload the WifiStatus example per the instructions on the Arduino Site/Examples/Yun. However, when I hit the serial monitor button it is supposed to print out the relevant Wifi stats, instead it says "unable to connect" and the final line goes a bit further..."unable to connect: is the sketch using the bridge". Any ideas? A post suggested reseting the 32U4, which I did, but no luck.
Incidently, all of this is over Wifi. Board and port are set per instructions. Yun pings fine and receives the uploaded sketch fine.
