Hi Guys,
I am stuck trying to use an SD card breakout board from Sparkfun.
Sparkfun uSD Breakout (Level Shifter)
This SD card uses SPI and a chip select on Digital Pin 8, as well as a card detect on Digital Pin 9. Confirmed my wiring is correct and the chip is getting 4.7 V. Below is my sketch I am using to setup / test the card.
The problem occurs when attempting to initialize the card. It fails repetitively, then suddenly works. Sometimes it never initializes.
On a side note I did try two of these breakout boards on my Yun and Uno. Both had the same results.
My SD card is formatted as FAT32 and is 8GB. The card is a Kingston (brand new) and uses an unit allocation size of 4096 bytes.
Here is my sketch:
* A simple file logger that allows the user to write to a file on the µSD card
* using the Arduino IDE Serial Monitor (57600 baud). Entered text is written
* to the µSD card every 20 characters, but to make sure everything is written
* append 'EOF' to your writing. Doing so writes everything remaining in the
* buffer to the file and reads back the contents of the file.
#include <SPI.h>
#include <SD.h>
File fd;
const uint8_t BUFFER_SIZE = 20;
char fileName[] = "demoFile.txt"; // SD library only supports up to 8.3 names
char buff[BUFFER_SIZE+2] = ""; // Added two to allow a 2 char peek for EOF state
uint8_t index = 0;
const uint8_t chipSelect = 8;
const uint8_t cardDetect = 9;
enum states: uint8_t { NORMAL, E, EO };
uint8_t state = NORMAL;
bool alreadyBegan = false; // SD.begin() misbehaves if not first call
// Standard Arduino setup function
Serial.begin(57600);
// pinMode(10, OUTPUT); // change this to 53 on a mega // don't follow this!!
// digitalWrite(10, HIGH); // Add this line
while (!Serial); // Wait for serial port to connect (ATmega32U4 type PCBAs)
// Note: To satisfy the AVR SPI gods the SD library takes care of setting
// SS_PIN as an output. We don't need to.
pinMode(cardDetect, INPUT);
initializeCard();
// Arduino calls this function over and over again when running
// Make sure the card is still present
if (!digitalRead(cardDetect))
initializeCard();
if (Serial.available() > 0)
readByte();
if (index == BUFFER_SIZE)
flushBuffer(); // Write full buffer to µSD card
// Do everything from detecting card through opening the demo file
void initializeCard(void)
Serial.print(F("Initializing SD card..."));
// Is there even a card?
Serial.println(F("No card detected. Waiting for card."));
while (!digitalRead(cardDetect));
delay(250); // 'Debounce insertion'
// Card seems to exist. begin() returns failure
// even if it worked if it's not the first call.
if (!SD.begin(chipSelect) && !alreadyBegan) // begin uses half-speed...
Serial.println(F("Initialization failed!"));
initializeCard(); // Possible infinite retry loop is as valid as anything
alreadyBegan = true;
Serial.println(F("Initialization done."));
Serial.print(fileName);
if (SD.exists(fileName))
Serial.println(F(" exists."));
Serial.println(F(" doesn't exist. Creating."));
Serial.print("Opening file: ");
Serial.println(fileName);
Serial.println(F("Enter text to be written to file. 'EOF' will terminate writing."));
// This function is called after the EOF command is received. It writes the
// remaining unwritten data to the µSD card, and prints out the full contents
// of the log file.
void eof(void)
index -= 3; // Remove EOF from the end
flushBuffer();
// Re-open the file for reading:
fd = SD.open(fileName);
if (fd)
Serial.println("");
Serial.println(":");
while (fd.available())
Serial.write(fd.read());
Serial.print("Error opening ");
fd.close();
// Write the buffer to the log file. If we are possibly in the EOF state, verify
// that to make sure the command isn't written to the file.
void flushBuffer(void)
fd = SD.open(fileName, FILE_WRITE);
if (fd) {
switch (state) // If a flush occurs in the 'E' or the 'EO' state, read more to detect EOF
case NORMAL:
case E:
readByte();
readByte();
case EO:
readByte();
fd.write(buff, index);
fd.flush();
index = 0;
fd.close();
// Reads a byte from the serial connection. This also maintains the state to
// capture the EOF command.
void readByte(void)
byte byteRead = Serial.read();
Serial.write(byteRead); // Echo
buff[index++] = byteRead;
// Must be 'EOF' to not get confused with words such as 'takeoff' or 'writeoff'
if (byteRead == 'E' && state == NORMAL)
state = E;
else if (byteRead == 'O' && state == E)
state = EO;
else if (byteRead == 'F' && state == EO)
eof();
state = NORMAL;
Here is the output from the serial monitor.
Initializing SD card...Initialization failed!
Initializing SD card...Initialization done.-demoFile.txt doesn't exist. Creating.
Þ>Opening fdemoFile.txt
Þ>Enter text to be written to file. 'EOF' will terminate writing.ÊÞ>Initialization done.ÊÞ>demoFile.txt doesn't exist. Creating.ÊÞ>�ù•¶:?ý”demoFile.txtÊÞ>Enter text to be written to file. 'EOF' will terminate writing.ÊÞ>Initialization done.ÊÞ>demoFile.txt doesn't exist. Creating.ÊÞ>�ù•¶:?ý”demoFile.txtÊÞ>Enter text to be written to file. 'EOF' will terminate writing.ÊÞ>Initialization done.ÊÞ>demoFile.txt doesn't exist. Creating.ÊÞ>�ù•¶:?ý”demoFile.txtÊÞ>Enter text to be written to file. 'EOF' will terminate writing.ÊÞ>Initialization done.ÊÞ>demoFile.txt doesn't exist. Creating.ÊÞ>�ù•¶:?ý”demoFile.txtÊÞ>Enter text to be written to file. 'EOF' will terminate writing.ÊÞ>Initialization done.ÊÞ>demoFile.txt
Hopefully there is someone much smarter than me to understand why this card isn't immediately being read. I am not confident using this in a design with intermittent failures.
-NB
