Arduino Yun
Hello
Does the Arduin yun need to be connected to Ethernet when using the libraries BridgeClient class and BridgeServer class? Is it possible to use BridgeServer and BridgeClient class over wifi?
Thanks
Ethernet and WiFi are interchangeable: anything you can do over WiFi, you can do with the Ethernet port, and anything you can do with Ethernet, you can do with WiFi. You can even use both at the same time.
Nothing in the Bridge Library cares about the type of network connection: it works equally well with both.
